Home › Forums › Product Discussion & Questions › BeoLink › Masterlink – Play button turns whole system off › Reply To: Masterlink – Play button turns whole system off
#74342
Madskp
GOLD Member
Now I’m wondering whether it has to be a genuine video source or whether it’s possible to fool the system with an additional source into the 1611 as in Matador’s illustration?
I am not sure the 1611 can do that just based on sound input, as it might need the datalink signal from a TV.
Another possibility is the NL/ML converter Carolpa mentions. If you do not need it for connecting NL equipment you might still be able to utilise it as a link room instead of an BL Active.
I have a few other ideas that may not work, but will try to test them in the comming days and report back.
