Home Forums Product Discussion & Questions BeoLink Masterlink and Network Link – some help needed
Viewing 20 posts - 41 through 60 (of 70 total)
  • #61901
    CharlieWednesday
    GOLD Member
      Yes, I read the full product description on Steve’s site and it does say they are fully wired Mk2 cables, so I’ve ordered one, as it’s bound to come in useful.
      When it arrives, I’ll try this experiment.
      #61912
      Millemissen
        I am pretty sure that you will not be able to activate anything/Essence from the linkroom.
        But, if you start playback from it directly – using the Beo4 (supposedly there is an ir eye connected) or a Beoremote One/BT respectively the B&O/the Spotify app – you can unmute/play and listen in the linkroom/s.
        Looking forwards to your findings!
        CharlieWednesday
        GOLD Member
          Steve/Sounds Heavenly are closed until 6th January anyway so I won’t be able to perform the test until they open again and send the cable.
          One other question while I am on though – I have a Windows 11 PC which I have set up to be discoverable as a media server, and I have a lot of digital music on it.  When I go to the Music options in the B&O app, and select the HomeMedia option, it discovers that PC and it is added the app as a media server.  Despite this, it doesn’t seem to have made any difference – I assumed this would mean that I would be able to browse music stored on that PC/media server directly in the B&O app and initiate playback from there, but I can’t – the only way I have found to play music from that PC to the Essence is via Bluetooth.
          The user guide for the Essence is quite vague, but it does seem to indicate that once a media server is successfully added (albeit in the old Beomusic app), you could select music from that source directly in the app.  Should this also be possible in the newer B&O app?
          #61939
          Guy
            I can’t test it again now but I used the B&O app to successfully play music stored on my QNAP NAS to my Essence. I used the home media option on the app to select my NAS.  I will have a look at the server settings tomorrow to see if anything can be read across to Win11.
            #61947
            CharlieWednesday
            GOLD Member
              I’ve had another look this morning and maybe it needed some time – the app now shows that PC as s source in the Music section (if you scroll down past the crappy Deezer content I never use), but it doesn’t show any albums/tracks.
              I know that PC is working okay as a streaming device as I can see the device (and its content) on other devices, just not on the B&O app.
              Screenshot:
              Screenshot_20241227-074011
              #61949
              Guy
                I just reconnected my Essence and had a quick play.  Initially I couldn’t access my QNAP server, but strangely the Essence would still play a couple of tracks from an earlier playlist.
                I then deleted and re-installed the B&O app, added the QNAP server and it worked again.  Various screenshots follow:
                IMPORTANT EDIT:  You have to press the + sign to the right of the ‘available server’ for it then to become a useable ‘HomeMedia server’ in the app.
                IMG_8967
                IMG_8972
                IMG_8973
                Screenshot 2024-12-27 at 12.07.17
                In the above examples the music files on my QNAP NAS are stored in FLAC format.  A quick google search for supported formats gives the following:
                Supported audio formats: MP3, WMA, AAC, ALAC, FLAC, WAV, AIFF Standard sample rates up to 192 kHz, stereo and up to 24 bits Note: WMA lossless is not supported
                Luckily I have a spare Win11 laptop here at the moment that I am fixing for a relative (my desktop is Win10), so later today I will set that up a Win11 server and experiment further.
                #61957
                Guy
                  Update:  I just tried Win11.  I copied a few FLAC albums, and a single mp3 album onto the Win11 laptop and enabled the built in DNLA media serve – screenshot as below:
                  Screenshot (2)
                  On the B&O app, I went to Music, Settings, HomeMedia and pressed ‘add new’.  It searched for ages and nothing showed.  I then went back into the Win11 screen above and where it says ‘name your media library’ I changed the name by deleting the space between ‘Nell’ and ‘Laptop’.  When I pressed ‘OK’ the Win11 server immediately appeared on the B&O app, so I pressed the ‘+’ to add it and the Win11 albums were immediately available.  Screenshots below:
                  IMG_8975
                  IMG_8977
                  IMG_8980
                  Both FLAC albums and mp3 played fine to the Essence, with cover art showing on the app.
                  So it would seem that the B&O is hesitant to find new HomeMedia servers, and maybe my Win11 Media Library name change forced some kind of rebroadcast over the network that then triggered detection.
                  Happy to investigate further if you have no success.
                  EDIT:  I just tried all the above from my Windows 10 Desktop with exactly the same result:  Changing the media library name triggered the server to appear in the app.
                  #61960
                  CharlieWednesday
                  GOLD Member
                    Thanks for all of the experimentation, it’s really helpful.  I have renamed my media library (removing an apostrophe and a space), removed it in the app, and tried to re-add it.  I’m still not getting anything, but at least I know it worked for you after some trial and error, so I’m sure I’ll get there in the end!
                    All of my digital music is ripped from my CDs anyway, but I think it would be handy to be able to access the digital music from a media server for link rooms – I intend to set up 2 link rooms with Beolab 2000 or 3500 (1 in bathroom, 1 in garage-used-as-gym), and it would be nice to have a full digital music library available in both.
                    My Beolink NL/ML converter arrives tomorrow, so I want to solve this before I have to move on to solving that!
                    #61963
                    Guy
                      No problem – happy to help!  Did you see my ‘Important Edit’ in bold in my post two above, about clicking the + button to change the server from ‘available’ to ‘added’?  It’s not very intuitive!
                      Otherwise not sure what to try!
                      #61964
                      CharlieWednesday
                      GOLD Member
                        Yes I did see that, it is definitely added and the HomeMedia server shows as added in the app, I just can’t get it to show any of the music that’s stored on it – yet!
                        #61970
                        Guy
                          Sorry if this is obvious, but on the Win11 computer, did you open ‘Media Player’ (not the old ‘Windows Media Player’ legacy) and under ‘Settings’ then ‘Libraries’ add the folders where your music is stored?  Whilst playing around and changing music libraries I also had to click the ‘Refresh Libraries’ button in the Media Player settings, whereupon this refreshed the music (albums etc) visible on the B&O app.
                          #61971
                          CharlieWednesday
                          GOLD Member
                            Don’t worry it wasn’t obvious (I’m not familiar with media sharing in Windows), but yes I had found that, and I had added my Music folder to the library.
                            I have other devices on the network which can see the music on that PC (it’s shown on other devices as a ‘Media Device’).  It’s only the B&O app that can’t see the content on it, so far.
                            #61986
                            CharlieWednesday
                            GOLD Member
                              Going back to the original reason for this thread, my Beolink Converter NL/ML arrived today.  I connected it to my router via a network cable, then connected it into my ML network.  It recognises my Essence, even though that is only connected via WiFi – I had assumed I would need to make a wired connection to the Essence, but that is not the case, which is useful.
                              It was quite easy to set up but I cannot control Spotify Connect via remote control, which is what I was hoping.
                              I have set the BL Converter’s ML Role as ‘Source Center’, and this allows me to select my Essence as the NL product for N.Music and N.Radio.  I was able to set N.Radio to link to ‘B&O Radio’ on the Essence, and that works – I can select that with my Beo4, and use the number keys to choose favourite stations.
                              I cannot however select Spotify, as it isn’t available – when it gives me Essence sources available to use, Spotify is not listed (but Deezer is):
                              blc
                              It’s a shame, as the setup manual for the BL Converter shows that Spotify is available as a source, but in the example given that is when using a Beoplay V1 rather than an Essence.  Seems odd that it’s not available on the Essence Mk2, given that it does have Spotify connect?
                              I did find a way around it, kind of.  Instead of using Spotify Connect to play music to my Essence, I can just connect via Bluetooth instead, having set the N.Radio source to ‘Bluetooth’ in the BL Converter.  Once connected, if I play Spotify on the connected device, I can use my Beo4 to pause, play, skip tracks.
                              So, I might decide to cancel my Spotify subscription and sign up to Deezer instead!
                              #61989
                              Guy
                                According to this thread https://archivedforum2.beoworld.org/forums/t/15899.aspx (which is one of the ones I linked to earlier in the thread) you should only be able to distribute Spotify to other devices that support Spotify Connect on the NL network.
                                Given that the NL/ML Converter is part of the NL/ML network, that would suggest that you should be able to connect PL speakers to the NL/ML converter and then play/control Spotify.
                                I have relatively new to Spotify, and am wondering whether the problem can basically be explained by the difference between ‘Spotify’, and ‘Spotify Connect’.
                                #61990
                                CharlieWednesday
                                GOLD Member
                                  Ah, I don’t want to connect my speakers direct to the BLC because I have my speakers in a surround setup, connected to my Beovision 7 (BL Penta front, BL6000 back, BL7.4 cinema centre, and BV Cona subwoofer, driven with a BL Passive).
                                  The BV7 is in Opt2, the Beosound 4 in Opt0, so the BLC has been set as ‘Source Center’, as it cannot be set as an A or V Master in that setup.
                                  I’m a little disappointed that I cannot select Spotify as a source with my Beo4 and control it, but it’s not the end of the world; I can control it after a fashion if I use Bluetooth.
                                  I’ve only had the thing since this morning so I’ll be experimenting further, but I am seriously considering a move from Spotify to Deezer.
                                  #61992
                                  CharlieWednesday
                                  GOLD Member
                                    One thing I didn’t realise by the way was that I would be able to select any of my ML sources (CD, TV and so on) via the app, and then also have basic remote control via my phone of those sources (skip tracks, play/pause, volume).  That’s really nice!
                                    I have an old Masterlink gateway which allows me to do that kind of thing via a web interface on my PC too, so now I can control everything from everywhere!  I’m looking to upgrade that to the newer Beolink Gateway, but I haven’t found one at a good enough price yet.
                                    #62205
                                    CharlieWednesday
                                    GOLD Member
                                      Update – I still have not been able to get my shared music folder on my PC to show on the B&O app.  It shows the device (a tablet PC running Win11), but not the contents.  I’m sure this will be a Win11 issue (who is surprised!?).  I think I’ll look on eBay for a cheap NAS and see if I can get it working that way.
                                      One good thing though – I did discover I can control music (including Spotify) from that PC, simply using a Bluetooth connection.  If I initiate playback via Spotify (or MP3s with Windows Music app), with the PC connected to the BS Essence via Bluetooth, my Beo4 will allow basic control – play, pause, skip tracks.  If the PC is on and I select N.Music with my Beo4, it will start playback from the PC, of whatever track was last playing in whichever app is open.
                                      I’m still waiting for the adapter cable to arrive to connect my BS Essence to my Beolink Passive, then connect an MCL2A and MCL2AV to perform the other suggested tests – I’ll keep you posted.
                                      #62210
                                      Guy
                                        It’s strange that mine worked.  I still have a couple of Win11 laptops here so I can experiment further if required.  I can’t remember, but is your B&O app running on android?  If so, perhaps the problem is specific to Win11 to android?  If so, any chance you can try the app on an iPhone?
                                        #62211
                                        CharlieWednesday
                                        GOLD Member
                                          Yes, I’m not an Apple user at all, so I use an Android phone (Pixel 6).  I also dug out an old Android tablet to try it on that, but it was too old – the B&O app would not install.
                                          Might be worth a try – next time I have a visitor to the house who uses an iPhone, I’ll see if they’ll let me borrow it for half an hour.
                                          I know that B&O have always integrated better with Apple rather than Android, but I’m just not an Apple fan.  Can’t say I’m really much of an Android fan either for that matter, but there’s no other alternative!
                                          #62216
                                          patcherley
                                          GOLD Member
                                            How are you sharing music from Win11. When I had to buy a replacement PC with Win11 I had problems with Legacy Music Player and had to set up a local user and share music from there.
