Home › Forums › General Discussion & Questions › General Discussion & Questions › Master Link Junction Box Wiring
- This topic has 2 replies, 2 voices, and was last updated 2 months, 2 weeks ago by
DAA.
25 January 2026 at 12:29 #72813
DAA
BRONZE MemberHi there – apologies if this question has been asked, I couldn’t find a specific thread – but when wiring up a junction box (the small one) to join two ML cables do I need to strip the individual wires back to the cable or when using the push tool should the wires still be sheathed?
hopefully that makes sense!
25 January 2026 at 12:44 #72814 GuyModeratorThe inner wires should still be sheathed – the metal that grips the cable should cut through this sheath as the cable is pushed into place.
EDIT: I have attached the junction box instructions because I am not sure whether we have them in the library.
You must be logged in to view attached files.Location: Warwickshire, UK
25 January 2026 at 13:37 #72823DAA
BRONZE MemberExcellent, thank you – that’s what I thought, but wanted to make sure.
