Home › Forums › Product Discussion & Questions › BeoLink › Master link help
- This topic has 1 reply, 2 voices, and was last updated 2 years, 4 months ago by
Guy.
4 November 2023 at 04:46 #50217
gpapilaris
BRONZE MemberI live in the US, looking for an installer with master link experience.
Must replace my BV 7-55 but want to save my master link connecting BS 9000 to other rooms. I know options available to update my TV surround situation. I’d like to preserve the option of listening to the BS 9000 in the other rooms without connecting to the TV. Thanks
4 November 2023 at 18:41 #50218 GuyModeratorYou should simply be able to unplug the ML cable from the BV7-55 and this should not prevent the BS9000 being listened to in other rooms.
However, assuming that you are currently listening to the BS9000 through the TV and its speakers, then you will need a solution for that room. If the BS9000 is in the same room, the simplest solution is simply to add BeoLab active speakers to the BS9000.
