Home › Forums › Product Discussion & Questions › Other › Making a short conversion lead for use with Beovision tv’s
- This topic has 3 replies, 2 voices, and was last updated 1 year, 5 months ago by
stotty1111.
21 October 2024 at 18:55 #60347
stotty1111
GOLD MemberHi all
I have an old BV 7 motorised tv stand, and a BV 10 tv.
I am wanting to connect the tv stand output to the stand, I have a rectangular 5 wired lead, and also a line socket which will connect to the 5 pin DIN plug.
Anyone out there have the wire functions ie pins 1 – 5 of the rectangular plug and also the wire in functions ie pins1-5 of the din plugand their orientation?
I hope my question is clear, it’s difficult to describe what I am looking for!
thanks
Tony S
21 October 2024 at 22:15 #60350 Guy
ModeratorHi Tony,
I have just answered your PM and attached this from the BV6 manual: (I think you already have the 8-pin connection list?)
But have you considered buying a purpose built lead from here? https://shop.oneremote.dk/shop/69053-oneremote/4172-tv-stand-converter-snut/
I know from experience that the BV10-32 will fit onto the BV7-32 stand, but there is a problem with the geometry of the stand components versus the Centre of Gravity of the BV10-32.
Here’s a side view of the BV7 stand:
And a side view of the proper BV10-32 stand:
When you put a BV10 on the BV7 stand, the TV drops all the way downwards and tilts fully upwards due to the orientation of the two (near parallel) cross members. The different orientation/geometry of the BV10 stand hold the TV (stops it dropping) let allows you to tilt the screen up or down. The entire mechanism appears stiffer and more controllable.
When I temporarily used a BV7 stand for my BV10-32, I wedged a rectangular piece of rubber in the gap between the supports to stop the TV dropping downwards.
21 October 2024 at 22:24 #60351 Guy
ModeratorSimilar discussion (and copy of rectangular plug connections) in this old thread: https://archivedforum2.beoworld.org/forums/t/36445.aspx
27 October 2024 at 10:09 #60475 stotty1111
GOLD MemberThanks to Guy for his kind help with information etc.
I have now made up a conversion lead using a micro fit plug with attached cables and an 8 pin DIN line socket.
And yes, it works!!! 😉
I am about to contribute a piece about the repair of the microfit plug on the rotating stand using Farnell parts and the conversion piece
Hopefully I have some photos to mount but my camera started playing up during the fabrications.
I will also outline a solution to the stand geometry and the viewing angle of the 10-40 tv
Currently the vertical angle for viewing is held by some cable ties around the pole and the rear bottom central cable mount at the base of the tv — it works but does not look good. I haven’t got a cable cover so not a problem.
Anyone out there got said cable cover they would be willing to part with for an exchange of funds — colour doesn’t matter!
Cheers
Tony S
