Home › Forums › Product Discussion & Questions › BeoCord › Lubricating Sintered Bearings in Beocord 8000/9000
- This topic has 22 replies, 5 voices, and was last updated 2 years, 11 months ago by
sonavor.
9 May 2023 at 18:03 #44755
sonavor
BRONZE MemberIs that encoder tool something you made or is it something that can be bought? If the latter, can you post a link for it?
Thanks,
sonavor9 May 2023 at 21:30 #44756Glitch
BRONZE MemberThe encoder is a Calt PD30-8G1000BST5. I believe that you can buy it on Amazon (mine was purchased elsewhere). The brass adapter to mount the encoder wheel on the motor or capstan shaft and the magnetic mounts for the encoder pickup where both custom fabricated.
Glitch
10 May 2023 at 21:09 #44757sonavor
BRONZE MemberI tried your “easy” motor opening method and it worked great. No more Dremel and debris from the cutting. Best tip I’ve received in a while. Thanks again.
-sonavor
