Home › Forums › Product Discussion & Questions › BeoLink › List of NL based products
- This topic has 7 replies, 3 voices, and was last updated 3 years, 4 months ago by
beojeff.
22 October 2022 at 02:44 #40037
Frog
GOLD MemberHi,
is there a list of NL – based products? It would be useful as it will inform what would work with a BeoLink gateway etc.
23 October 2022 at 09:36 #40038 MillemisBRONZE MemberI can not present a complete list.
However, if you start with the Beoplay V1, BV11, the Essence MK2, the BS Moment…..everything thereafter, that is network based, will support NetworkLink.
I’d say, that the NL/ML Converter also is in this category.MM
23 October 2022 at 18:12 #40039beojeff
BRONZE MemberOn the now defunct “beointegration” site there was a document that went into detail as to which products with what firmware would work to what degree with the gateways. I agree with MM that just about any MCL, ML, or NL product can work with the gateway or BLI using an NL/ML Converter. If you have NL or mozart products, it just makes sense to bring everything else up to date with NL/ML Converters.
23 October 2022 at 18:15 #40040beojeff
BRONZE MemberP.S. I have EIGHT NL/ML converters in my NL network. It all works seamlessly.
23 October 2022 at 18:53 #40041Frog
GOLD MemberYes, I know you use 8. I tent to have two networks and one join so I only need one per house, but in this case, I would use a second.
I guess my question was more to do with the beososound products – the mk2 beosound a1 would be great if it was NL comparable….
23 October 2022 at 19:01 #40042beojeff
BRONZE MemberWell, you’ll be out of luck with the standalone products. E.g., Beosound Century, Beosound 1 (the old one with the CD player), Beoplay A1, Beoplay A2, 12, 15, 17, 2o, etc. You need products intended to work with any B&O network to work with a gateway/bli.
23 October 2022 at 19:03 #40043Frog
GOLD MemberYes, more’s the pity. It seems B&O are taking a different tack to the old days for multi-room integration. It’s a shame.
23 October 2022 at 20:03 #40044beojeff
BRONZE MemberI do agree with you that the A1 and 15/17/20 would be great multi-room speakers.
