Home › Forums › Product Discussion & Questions › BeoLink › Link Speaker – no video sources
- This topic has 5 replies, 3 voices, and was last updated 10 months, 3 weeks ago by
CharlieWednesday.
5 May 2025 at 19:20 #65438
CharlieWednesdayGOLD MemberI’m hoping this is just a(nother) thing I don’t know but is common knowledge for the experts here!
I cannot get the sound from video sources to play through my Beolab 3500 speaker. Audio sources are fine, but none of the video sources which are connected to my Beosystem 3 via HDMI.
It only seems to be the HDMI sources – I have an HDR2 connected as AV1 via SCART and I can get that sound via my BL3500, and I have also tested an audio source connected to the RCA inputs on AV4 and that works too, but none of the 4 HDMI sources will play through theBL3500.
Is this some kind of restriction with HDMI sources perhaps?
Note, My Beosystem 3 is in Opt.2, my Beocenter 9500 in Opt.0 (connected into the ML network via 1611 converter) and my Beolab 3500 is in Opt.4, as it’s in the same room, so I control it with LINK commands.
5 May 2025 at 20:00 #65441Madskp
GOLD MemberThere are some limitations in distribution of HDMI sources to masterlink.
This older thread might help you https://archivedforum2.beoworld.org/forums/t/40202.aspx
5 May 2025 at 21:25 #65442 CharlieWednesdayGOLD MemberI had a feeling it would be something to do with HDMI protection, thanks. I only really want one of the four HDMI inputs to be available to listen to from the link room speaker (my PC), so I’m wondering, if I get hold of an HDMI audio extractor with a digital coax out, then connect that to the BS3 and choose that as the sound input for that particular AV input, that might work. Those extractors are available cheap so I might get one and try it as an experiment.
Thanks for the help.
6 May 2025 at 09:12 #65446 GuyModeratorif I get hold of an HDMI audio extractor with a digital coax out, then connect that to the BS3 and choose that as the sound input for that particular AV input, that might work.
Yes that should work fine*. When hdmi inputs were first introduced on B&O TVs, users with ML systems were told to add a SCART connection in order to make sure that sound was distributed to link rooms. This was quite straightforward when, for example, DVD2 had both hdmi and SCART outputs.
* EDIT: Actually I am not sure that it will! It’s still a digital input to the BS3. Maybe an hdmi extractor providing analogue output that can be fed into the BS3 would be better.
* EDIT2: From the BS3 Userguide p14:
NOTE! Only sources with an analogue signal
can be distributed from a main room TV to
the link room system.I have had mixed results trying to distribute hmdi sources from BV10-32, as described in this post (and the wider thread): https://forum.beoworld.org/forums/topic/beovision-10-and-new-apple-tv/#post-51987
6 May 2025 at 19:15 #65463 CharlieWednesdayGOLD MemberThanks for the advice. I’ve checked the connection settings in the BS3 and if you use HDMI as the video source, it only gives you two choices for audio – HDMI, or SPDIF. It does not give you the option of using analog for audio if you are using HDMI for video.
I found an HDMI audio splitter with a digital coaxial out on Amazon, and it was cheap enough to be worth ordering, just to try it. I’ll let you know if it works when it arrives.
8 May 2025 at 20:41 #65500 CharlieWednesdayGOLD MemberUpdate – the HDMI audio splitter arrived, so I connected it as AV4 with HDMI D used as the video input and SPDIF used as the audio input. As I suspected, this works for the main speakers connected to the Beosystem 3, but not the link speaker.
It’s specifically sound from my PC I was hoping to get through the link speaker, so I’m going to conduct another experiment. My PC has a digital audio out socket, but it’s optical not coax, so I’ve ordered a little converter to convert optical to coax. I’m wondering: if the sound is coming from a separate source, and not split-out from the HDMI, maybe that will work. I think it’s unlikely to be honest, but worth a try. I’ll add another update when I’ve tried that.
