Home › Forums › Product Discussion & Questions › BeoVision › Lid problem Beosound 9000 MK3
- This topic has 1 reply, 2 voices, and was last updated 3 years, 4 months ago by
matador.
14 November 2022 at 01:05 #40784
lossi
BRONZE MemberBeovision 9000 MK3
Hi, have a problem with the glass lid. The lid does not open / close when pushing the knob.
Can open close the lid easy by hand but lid not keeping end position when in closing/open position.
Most prob driving belt is dammaged ? How to renew the belt, what need to be dismantled ?
Tks Ralf
16 November 2022 at 19:41 #40785 matadorModeratorI suspect you’re talking about a BeoSOUND 9000, multi CD player, right?
If so, I suggest you edit your post title and you may then have more answers.
Most likely the belt yes, google Beoparts, I’m quite sure they must have correct belts.
From memory you just have to remove the top parts and it’s not a big deal.
Hope this helps.
