Home › Forums › General Discussion & Questions › General Discussion & Questions › LG update to newer WebOS – question?
- This topic has 8 replies, 4 voices, and was last updated 1 year, 11 months ago by
Severed_hand_of_skywalker.
5 April 2024 at 03:20 #54099
Millemis
BRONZE MemberNow LG is rolling out the update of the OS for earlier tv models.
My C2 was offered the update to WebOS23, but I am not sure, that I want it.
I hardly use the UI of the tv – just the tuner occasionally.
Main source is an ATV, a CC dongle and the Blu Ray player (all connected to the BST).Does it makes sense to upgrade – any downsides?
What is your experience, if any?MM
5 April 2024 at 18:40 #54100patcherley
GOLD MemberI have updated my Eclipse, apart from the UI haven’t noticed any real difference, not sure I really like the new UI. But again I also don’t use the UI much at all, it I watch a TV programme I go straight there with the BeoRemoteOne short cut button.
Favourite Product: Beolink 7000
5 April 2024 at 19:04 #54101Sandyb
BRONZE MemberI updated my panels – no issues.
Like most I barely use the webOS UI – though there is now the option to have the screen timeout / screen saver as a simple information window – clock and weather.
I actually enabled this – largely as the post update wizard shows it to you, so it’s a few clicks to enable – and actually dont mind it. Just a black screen with a simple clock on it.
Otherwise, no issues with the update.
5 April 2024 at 22:39 #54102Sandyb
BRONZE MemberJust to add….while I did update both my rooms to the new webOS, I hadn’t used my main living room Theatre/LG setup after updating.
While my standalone bedroom Theatre/LG was fine with the new webOS, my living room setup seemed to lose the LG integration – example being all the internal sources were gone from the BR1 etc etc.
So I had to re-establish the LG/B&O webOS integration – which was a bit of a messy process, took a few attempts, but back to normal now.
Bit odd, I only had to do this on one of my Theatre setups.
5 April 2024 at 23:05 #54103 Millemis
BRONZE MemberThanks for the update
‘….bit of a messy process, took a few attempts.’
Which were these attempts – what did you have to do……..just in case?MM
5 April 2024 at 23:36 #54104Sandyb
BRONZE MemberGuess its the same as when you first setup a BST/LG from new.
i.e. the B&O app page for the BST has the “Enable LG/B&O app integration” type banner / message.
The difference (compared to box fresh and new) was that my LG already had the B&O webOS app installed. So, what to do?
I forced the issue a bit, by deleting the webOS app and re-installing it. The B&O app says to restart the TV when the app is installed, which I did but “integration” didnt take hold / re-establish itself. I went round this loop a couple of times, and then just rebooted the Theatre, which seemed to re-establish the integration.
I guess, once the integration had disappeared initially, I should have perhaps just rebooted the Theatre. Not sure deleting/re-installing the B&O webOS app process was necessary – but who knows.
Anyway, all good now.
6 April 2024 at 08:43 #54105 Millemis
BRONZE MemberOk – I think I’d better turn off the update.
Not in the mood for such a ‘messy process’.
My combo run just fine right now.By the way – the tv did not offer the update yesterday by turning on.
Maybe it only happens a couple of times ?MM
6 April 2024 at 18:13 #54106Sandyb
BRONZE MemberAnother note to those who have updated webOS.
I noticed, after updating, that when using internal webOS apps the LG was passing PCM to the Theatre. Observed this using Disney+ and Apple TV+ apps.
Never seen this before – prior to the update, internal apps were always passing bitstream to the Theatre.
Never looked at the Sound settings of the LG before, but when I did (Sound/Advanced Settings / Digital Sound Output) it was showng the Digital Sound Output set as PCM. I reset it, in this menu, to Pass Through. Everything then shows as expected (DD / DD+ / Atmos etc) in the B&O app.
What surprised me was that – using an Apple TV+ Atmos show – using Pass Through and allowing the Theatre to do its thing sounded a good deal better than when the LG was set to PCM.
Not a scientific sample I grant you, but did surprise me. Not relevant to those who only use an Apple TV box
Anyway, thought I’d share.
7 April 2024 at 19:44 #54107 Severed_hand_of_skywalker
BRONZE MemberI did mine first day on My G2. No issues. No real point though if you don’t use the TV os. I sure don’t use it, still terrible.
