Home › Forums › Product Discussion & Questions › BeoSound › Theatre › LG OLED C3 77 with BV Theatre – Slightly bent screen
- This topic has 2 replies, 2 voices, and was last updated 2 years ago by
martin01.
5 March 2024 at 12:48 #53220
martin01
BRONZE MemberHi,
I have since a couple of weeks ago bought a BV Theatre with a LG OLED C3 77. What I can see when I stand from the side of the TV is that the screen is “perfectly” bent a little. Is this normal?
I have read on several forums regarding LG OLED C-models that a lot of people have a slight bent in the screen. Does anyone with this combo (LG OLED C3 with BS Theatre) experienced a slight bent in the screen?
Best Regards
Martin5 March 2024 at 13:58 #53221TinusAMS
BRONZE MemberIt’s quite common for OLED panels, especially the larger sizes. As long as your picture isn’t affected when looking directly at it I shouldn’t worry too much about it.
I currently have a 55” G3 with Theatre also with some (very) light bends. I had way worse bends in my 65” Sony A90J, but it didn’t affect picture quality.
5 March 2024 at 14:21 #53222martin01
BRONZE MemberGreat thanks for answer. My old Eclipse with LG OLED G1 screen was 100% straight. I thought that the G-model was at most 100% straight. I can understand that the very thin C-model could be bent a little.
I have now read on “reddit” that is seems very common with this “bent” screens. Sadly when combining a bent screen to the Theatre you can see the alignment to the soundbar that the screen is not 100% straight from the left to the right.
//Martin
