Home › Forums › Product Discussion & Questions › BeoMaster › Left channel issue on Beomaster 4000?
- This topic has 4 replies, 3 voices, and was last updated 1 year, 1 month ago by
Steve Adcock.
2 February 2025 at 22:02 #63339
Steve Adcock
BRONZE MemberHello from Las Vegas!
I have a 4000 with a dead left channel and before I go and do a total re-cap thought I might ask is there any known idiosyncrasies as to voltages on this unit. Because I am getting some weird ones.
It has that extra 8002135 board…loudness?….that had some out of spec resistors which I replaced but things are still not right.
The resistor marked 1500 ohms should be 2.7k like the one I replaced.
Any help would be greatly appreciated!
You must be logged in to view attached files.7 February 2025 at 13:36 #63515 matadorModeratorLast time I had a silent channel it was from the large output capacitors.
Should it happen again, i would start there.
7 February 2025 at 16:38 #63528Steve Adcock
BRONZE MemberThank you but I figured it out. Shorted TR51…..
9 February 2025 at 09:04 #63599Pindsen
BRONZE MemberHi,
Good that you figured it out.
You mention a 1,5kohm resistor you suggest shall be 2,7kohm – is it 566 at basis of TR53 and why do you suggest this changed value?/Pindsen
9 February 2025 at 17:23 #63620Steve Adcock
BRONZE MemberNo, it’s on the 8002135 board…image above…that is not on the schematic. Two 2.7k resistors were down to 1.5k so they were replaced with the correct value….
