Home › Forums › Product Discussion & Questions › BeoSound › Keyboard shortcuts for beomaster 5 playback control? (beosound5)
- This topic has 1 reply, 2 voices, and was last updated 1 month, 1 week ago by
Guy.
18 February 2026 at 14:12 #73963
SaltineSurfer
BRONZE MemberHi all, I have just connected my beomaster 5 box into my beoplay v1 using a DVI > HDMI lead and a SPDIF coax cable for the digital sound. Sounds superb! A big improvement over the NL/ML converter. Now the Beomaster 5 is connected to the v1 TV, what I’d like to achieve is control of playback on the v1’s remote via the V1’s PUC IR blaster. I’m hoping that the beomaster 5 can react to USB keyboard commands for play/pause next/prev, but by trial and error I can’t find anything obvious that works. All i can do is up/down and enter for navigating the menus, and R for presenting the slide-in menu. Does anyone know if there are specific playback controls via a keyboard? If so I can plug in a FLIRC device to map regular IR signals received to the relevant keyboard command presses. Many thanks.
19 February 2026 at 11:45 #74067 GuyModeratorInteresting setup! Does this old thread help?
https://archivedforum2.beoworld.org/forums/t/4801.aspx
