Home › Forums › Product Discussion & Questions › BeoCenter › identify component for Beocenter 4000
- This topic has 2 replies, 2 voices, and was last updated 3 years, 6 months ago by
Widget.
21 September 2022 at 03:41 #39125
Widget
BRONZE MemberHi, I’m carefully resurrecting a Beocenter 4000. I have isolated a faulty component and am having much difficulty identifying it. I believe it is some sort of adjustable tank circuit resonator.
It is on the outlet of the audio of the FM demultiplexer/decoder chip.
The text on the side is ‘5214 48 JL’ it is identified in the tech manual as ‘LP200 8030041 19/38 khz’
I’ve included photos of the component and the circuit diagram.
If you can help, thank you so much.
21 September 2022 at 16:43 #39126Dillen
ModeratorIt’s an MPX filter. It grounds remains of the stereo pilot.
You can fit any good similar filter – or ask at Beoparts for a good used original part.Martin
22 September 2022 at 11:17 #39127Widget
BRONZE MemberThank you Martin, that’s the info I needed!
I’ve found an equivalent component to buy.
Now to find out why the signal strength meter is is not working…
