Home › Forums › Product Discussion & Questions › BeoMaster › How to reinitiate N.Radio updates in BeoMaster 5 / BeoSound 5
- This topic has 1 reply, 2 voices, and was last updated 2 years, 4 months ago by
Guy.
16 November 2023 at 02:37 #50492
Luc
BRONZE MemberFor some reason my N.Radio updates got stuck on 13/2/2020 and I started missing newer stations and some older stations didn’t play anymore. I saw mention of the same problem in several posts but not a real proven solution.
So I contacted B&O Support and the solution appeared to be very simple: go into the Maintenance menu and Delete Databases! After that BeoMaster 5 reboots and starts downloading the complete actual N.Radio database again!
And this worked fine for me: after an hour or so I got 67397 ‘new’ stations re-downloaded from the portal. Some hours later the logos were also present. My failing stations play again now and I see plenty of new stations appearing.
So thanks to B&O Support for their clear, simple and effective solution 🙂
This is the link to the document: Beosound 5 N.Radio troubleshoot.pdf
Enjoy, Luc
16 November 2023 at 19:45 #50493 GuyModeratorThanks for this Luc. Sorry that you had problems posting – I think the spam filter didn’t like the link but it all works now.
