Home › Forums › Product Discussion & Questions › BeoVision › How to integrate BS Essence into BV14-55
- This topic has 5 replies, 4 voices, and was last updated 3 years, 7 months ago by
Sia43.
30 August 2022 at 09:39 #38714
SirPump
BRONZE MemberCan anyone help me to successfully integrate the Beosound Essece Mk2 into my Beovision 14-55. Which setting do i need to make?
With thanks!
30 August 2022 at 12:07 #38715 kuyttendaeleMemberDon’t know what settings are needed on the Essence but on the BV14:
Settings => Product Integration => Link to other products > <select your Essence>
After that: your Essence should be be visible in Settings => Sources list.
Karel.
30 August 2022 at 14:35 #38716 MillemisBRONZE MemberYou will also have to go (deep) into the settings of the Essence.
In the app navigate untill you reach the webinterface of the product.
’Configure’ and then ‘Settings’
There you will see ‘Beolink’ -> ‘Connect to other products’?
This is where you choose your BV.Don’t forget – both products must be on the same home network!
30 August 2022 at 14:50 #38717Sia43
BRONZE MemberMM, in the picture you’ve attached on Essence settings, there is a setting called “Lydsynkronisering”. Do you know if the setting is for removing potential audio delays with other B&O products?
30 August 2022 at 14:57 #38718 MillemisBRONZE MemberIt is – but not relevant in your case.
See:
30 August 2022 at 15:05 #38719Sia43
BRONZE MemberMM, thanks for your answer and the link. I assume then that the function isn’t compatible with Mozart based products!
