Home › Forums › Product Discussion & Questions › BeoSound › Theatre › How to add BS9000 as source to Theatre?
- This topic has 3 replies, 3 voices, and was last updated 3 weeks, 1 day ago by
mafanni.
7 May 2026 at 10:34 #123506
mafanni
BRONZE MemberHi,
my BS9000 is connected via Masterlink to an ML/NL converter.
The ML/NL converter sits in an adjacent area and has an IR-eye and 2x Belolab connected. I can play the BS9000 there and controlling with Beo 4.
I would like to add the BS9000 now as an additional source on the Theatre and play over the Theatre as well, controlling it with the BR1.
How to to that?
Attached are the settings of the ML/NL converter.
Thanks,
Erik
This topic was modified 3 weeks, 2 days ago by
mafanni.
You must be logged in to view attached files.7 May 2026 at 18:45 #123514 carolpaBRONZE MemberHi,
How to to that?
Thanks,
Erik
Simple answer: you can NOT add the BS9000 as an integrated source of the Theatre.
You can play the sources of the BS9000 through the Theatre though. Be sure the BLC and the Theatre are connected to the same network. Start f.e. a BS9000 CD. Choose JOIN on the Theatre BR1. The CD music played through the BLC (Beolink Converter NL/ML) should be heard on the Theatre.
The Beoconnect Encore didn’t surface as a commercial product. This product looked like to be the promise to connect ML devices and the Mozart, NL products (Theatre, BL8, BL28, etc………).
7 May 2026 at 19:22 #123515 MillemisBRONZE MemberThat should work well.
I do it the same way with my BM6500/CD6500.
7 May 2026 at 23:01 #123517mafanni
BRONZE MemberHi,
I just tried your solution, it works great 👍 Thank you so much for sharing.
Erik
