Home › Forums › Product Discussion & Questions › BeoSound › How disconnect multiroom on Beosound Essence and remote
- This topic has 7 replies, 4 voices, and was last updated 1 year, 5 months ago by
Guy.
7 November 2023 at 12:03 #50279
gumboots
BRONZE MemberHello,
How to disconnect multiroom
on Beosound Essence
and remote essence ? Cause I have no
multiroom only Beosound Stage and
a Beosound Essence.
7 November 2023 at 14:19 #50280 MillemisBRONZE MemberHi gumbots
Actually you have ‘a Beolink multiroom’.
Your two devices – Stage and Essence – do build a B&O network assuming they are on the same home network.But why do you want to disconnect?
7 November 2023 at 17:36 #50281gumboots
BRONZE MemberThanks Millemissen,
‘Cause I don’t need à Beolink multiroom they are in the same room.
Yes Essence and Stage are on the samedi Net work.
7 November 2023 at 18:17 #50282 MillemisBRONZE MemberThen just use them independently – nothing forces you to use multiroom.
P.S.
I suppose that you have speakers connected to the Essence.
What does the Essence Remote control?MM
8 November 2023 at 07:37 #50283gumboots
BRONZE MemberGood morning Millemissen,
Yes I have speakers connected to Essence. I see the Essence Remote control only The Beosound Essence.
8 November 2023 at 09:42 #50284 MillemisBRONZE MemberWhat is it that bothers you, what do you miss???
I guess I fail to see your problem.
Maybe someone else can chime in here.MM
23 August 2024 at 10:36 #58573Paul Dandurand
BRONZE MemberHi Gumboots, I have the same question.
Since Millemissen is curious as to why, not that it matters, at my end, I’m trying to undo Multiroom and then re-set it up as I’m not seeing the same image I saw earlier with the first set up in my B&O app.Maybe someone out there knows. If not, I’ll just ask B&O support. They’re pretty good at replying quickly and professionally. If I find out, I’ll post again.
23 August 2024 at 11:52 #58577 GuyModeratorSince Millemissen is curious as to why, not that it matters, at my end, I’m trying to undo Multiroom and then re-set it up as I’m not seeing the same image I saw earlier with the first set up in my B&O app.
How about a factory reset of the Essence? – this is explained in the relevant instruction manual, available here: https://support.bang-olufsen.com/hc/en-us/articles/360038206612-User-Guides-and-Software-Downloads
