Home › Forums › General Discussion & Questions › General Discussion & Questions › HELP! getting headphones “buzz” feedback
- This topic has 2 replies, 3 voices, and was last updated 3 years, 6 months ago by
Steve at Sounds Heavenly.
16 September 2022 at 03:29 #39072
Monsterzero
BRONZE MemberHello, I was hoping someone could help me understand how to resolve this issue. I have a Beocenter 9000 and recently received a connector from Sounds Heavenly, that plugs into the auxiliary DIN port into the back of the in and out connections on my FiiO K9 pro amp.
when I pause a song using listening through my headphones, there is a huge “hum/buzz “ sound that only gets worse when I increase the volume on my amp.
if I plug directly into the Beocenter headphones jack, there is no feedback sound at all. Also, when listening to music via Bluetooth or with the USB – C connection from the amp to my phone, I get no feedback in the headphones.
Is there a different way to connect an amp for headphones to the Beocenter that could reduce this feedback during stopped or paused play?
Thank you in advance.
16 September 2022 at 17:28 #39073Glitch
BRONZE MemberYou probably created, or already had and didn’t notice, a ground loop. It would be helpful to anyone trying to help you if you could provide a diagram of your system that includes all audio/data connections between components as well as power connections.
Glitch
17 September 2022 at 08:25 #39074 Steve at Sounds HeavenlyGOLD MemberHi Glitch,
Sorry to hear that you are having problems. Please can you try the cable in the Tape 2 socket of the Beocenter instead of the Aux socket? This should resolve the issue in most cases, but please ask if you need any further help.
Kind regards, Steve.
