Home › Forums › General Discussion & Questions › General Discussion & Questions › Help, can’t find resistor R3102 on my CD3300 servo board?
- This topic has 5 replies, 3 voices, and was last updated 1 year, 5 months ago by
987nick.
2 December 2024 at 14:20 #61287
987nick
BRONZE MemberI thought I’d fixed my CD3300, type 5142, as I managed to get it to play most of my CDs. I’ve replaced all electrolytic capacitors on the power supply, decoder board and servo board. But, after leaving it for a few days it now plays none of them. In most cases the TOC are read, but it won’t play.
I now want to check the laser power. The service manual says to put a meter across R3102 to check the mv. But, my servo board, number 5886 on the sticker, doesn’t seem to have that resistor.
I’ve attached pictures of both sides of the board and would really be grateful if someone could point me to the resistor.
You must be logged in to view attached files.2 December 2024 at 15:12 #61291 GuyModeratorDoes para 6 and 7 of this help – looks similar!
2 December 2024 at 17:15 #61293987nick
BRONZE MemberI’ve seen that and it does look familiar. And, that’s how I knew I don’t seem to have a resistor in the same place. My board has a gap.
6 December 2024 at 13:01 #61376987nick
BRONZE MemberJust to bump this, any other suggestions?
6 December 2024 at 13:38 #61379Glitch
BRONZE MemberIf you can’t find the part marking directly on the board, an indirect method might work. First find the part on the schematic and see which parts that it is connected to. Then search for the “connected parts”. It is sometimes helpful to track the connectivity to a obvious part (like one of the TDA chips) and start following traces from a specific pin number. Don’t forget to check both sides of the board. I recall working on a similar board and the resistor in question was a surface mount device mounted on the back side of the board.
Following the traces can also be helpful for finding convenient places to attach the test leads.
Glitch
6 December 2024 at 15:14 #61382987nick
BRONZE Member@glitch Thanks.
I’ve found it. Turns out it is in line with the IC by the ribbon connector and not to the side. Turns out the CD3300 service manual has another servo board detailed right at the end of the book. I was looking at the 1st one in the book. I should have learnt by now to read right to the end before I waste people’s time.
Now off to test the laser power output.
