Home › Forums › Product Discussion & Questions › BeoVision › HELP! BEOVISION 10-40
- This topic has 8 replies, 5 voices, and was last updated 1 year, 12 months ago by
bando user.
20 March 2024 at 03:19 #53628
bando user
BRONZE MemberHi everyone!,
Desperately in need of help. Was gifted a 10-40 beovision that was bought from a big hotel with no remote.
Tried all universal remotes nothing works to turn it on?
Someone from work mentioned it may have a ‘btl’ module that hotel tvs have and no remote would work?
Can anyone help please!! Anyone recommend a universal remote or code, ive tried one for all remotes with no luck, or is there any way to turn the tv on without a remote?
Or lastltly can anyone explain what a btl module is and how I can turn it off or remove if thats even possible or am I stuck with a beautiful looking dead weight?
20 March 2024 at 09:38 #53629 GuyModeratorHi and welcome to Beoworld!
You need to get hold of a Bang and Olufsen remote – preferably a Beo4. B&O use a different (higher) IR transmission frequency which very few universal remotes are able to replicate. When looking for a Beo4, try to find a newer one where the second row of buttons read DTV DVD CD as this will be most useful with that age of TV.
I think the module being referred to is possibly a BtB module, meaning ‘business to business’ – i.e B&O supplying a TV to a Hotel chain. These are usually removable but it is possible (not definite) that new SW will be required for the TV.
Try to get hold of a B&O remote first, and then have a play to investigate whether a BtB module is indeed fitted.
Come back here for more help if required.
20 March 2024 at 10:52 #53630Madskp
GOLD MemberAnother possibility for testing the TV is if you have an Apple TV with one of the confirmed working remotes mentioned in this thread https://forum.beoworld.org/forums/topic/apple-tv-siri-remotes-and-ir-beovision
you could be lucky that would start the TV although limited to turning on and volume control
20 March 2024 at 18:34 #53631 trackbeoBRONZE MemberLikewise an old Logitech Harmony Home Hub and its iPhone/iPad app. Annoying to configure, and to press on-screen buttons, but it’s cheap (used) and full-function.
20 March 2024 at 18:54 #53632 RavstedBRONZE MemberTV could be pin protected …
20 March 2024 at 21:48 #53633bando user
BRONZE MemberThank you Madskip
20 March 2024 at 21:49 #53634bando user
BRONZE MemberThank you so much Guy, really appreciate your help! i can get access to a beo one remote, so ill try that first over the week end and nlet you know how I get on.
20 March 2024 at 21:50 #53635bando user
BRONZE MemberHow would we know?
20 March 2024 at 21:52 #53636bando user
BRONZE MemberThanks Trackbeo, ill save that if nothing more simpler works!
