Home › Forums › Product Discussion & Questions › Other › HDR2 file format
- This topic has 3 replies, 3 voices, and was last updated 1 year, 9 months ago by
Guy.
15 July 2024 at 06:41 #57411
Madskp
GOLD MemberDoes anyone know what file format a HDR2 harddisk recorder use and if the files from the disk can be read on a PC or Mac if the disk is connected to them?
17 July 2024 at 15:42 #57452XavierItzmann
BRONZE MemberBetter to ask the manufacturer?
17 July 2024 at 17:37 #57454Madskp
GOLD MemberBetter to ask the manufacturer?
Well, the innnards might not be B&O, and guess that B&O support might not know much about this product now.
However reading about the topic for other brands, it sounds like the filesystem on a harddisk recorder might be properitary at not easily (if at all) readable on a computer, so might look for other methods of transfer
17 July 2024 at 21:15 #57462 Guy
ModeratorI took apart an old SkyHD decoder about a year ago and tried connecting the Hard Drive to my PC. I couldn’t read any files, but downloaded some software called ExPVR to decode the files – this worked and I could view the contents, but it was tricky to use and I am always a bit suspicious of free software.
Once you know the file type (and possibly the make of the innards if not B&O), you may be able to find similar software for decoding purposes.
