Home › Forums › Product Discussion & Questions › BeoSound › Theatre › Hdmi Theatre
- This topic has 6 replies, 2 voices, and was last updated 3 years, 4 months ago by
Marc.
3 December 2022 at 10:17 #41245
Marc
BRONZE MemberGuys, I connected my Nvidia Shield to the Theatre using Hdmi A. Is that a Earc connection or not?
3 December 2022 at 10:46 #41246Marc
BRONZE MemberI just read that it only has 1 eArc connection!!
Is it possible to choose the eArc connection for the Nvidia and Hdmi A for TV?
3 December 2022 at 11:12 #41247svendsen991
eARC doesn’t work like that. The ARC stands for Audio Return Channel and is used between TV and an AVR (Theatre in your case). And the “e” stands for “Enhanced” Audio Return Channel.
So eARC is only useful if you want sound to go in the opposite direction of the normal HDMI signal flow. Source (Shield) -> AVR (Theatre) -> TV
So:
Normal (video and audio): Source -> AVR -> TV
eARC (audio only): AVR <- TVNote eARC can coexist so you can get video and audio one direction and audio the other direction.
Hope it helps 🙂
3 December 2022 at 11:18 #41248svendsen991
Just to answer your original question no it’s not an eARC connection. The eARC HDMI port on the Theatre is only on the HDMI out port.
Some devices have something called eARC passthrough where the input port also have eARC but this doesn’t really make sense for the Theatre because that would mean using another audio system which kinda defeat the purpose of a soundbar 🙂
3 December 2022 at 11:34 #41249Marc
BRONZE MemberSo if I use a hdmi 2.1 cable from the Nvidia to the Theatre using Hdmi A, can I get Dolby Atmos or not?
3 December 2022 at 11:40 #41250svendsen991
Yes if the Nvidia and the content it’s playing support Atmos. The Theatre will extract it directly from the HDMI stream, so no need for eARC in your case 🙂
3 December 2022 at 11:42 #41251Marc
BRONZE Member???
