Home › Forums › Product Discussion & Questions › BeoMaster › Grounding a Beomaster 1900
- This topic has 1 reply, 2 voices, and was last updated 1 year, 12 months ago by
Ninni.
7 April 2024 at 12:07 #54153
mattg1919
BRONZE MemberHello!
I’ve got an Audio Technica AT-LP3 record player that I’ve connected to my newly repaired Beomaster 1900. I’ve got a phono-5din adapter to connect the record player but my question is, what should I do about ground? I have a lot of hum and static popping through the speakers when I touch the record player. I have a ground wire from the record player which is currently attached to the bottom of the 1900 but doesn’t seem to make a difference. Thanks.
7 April 2024 at 18:05 #54154 Ninni
BRONZE MemberHave you tried to connect the ground lead to the central pin (pin 3) on the DIN connector? Or to the DIN connector shield?
