Home › Forums › Product Discussion & Questions › BeoSound › Essence Remote IR
- This topic has 2 replies, 2 voices, and was last updated 2 years, 3 months ago by
XavierItzmann.
20 November 2023 at 01:23 #50619
XavierItzmann
BRONZE MemberOn this thread, two different contributors mention that the Essence remote has IR. Heretofore, I thought it was a BT-only device. Mine works very well in that regard, even if the volume adjustment is laggy by about 1/2 second, which is irritating.
Well, I put my Essence remote in front of my IR Eye and sequentially pressed the four buttons and turned the wheel and nothing happened. Pray tell, is there a manual that describes the IR functionality of the Essence remote?
Thanks in advance,
20 November 2023 at 10:02 #50620 MillemisBRONZE MemberI guess that depends on the age of your remote.
If I remember it correctly the first ones did not have the ir options.As for how to and what…
And have a look here.
20 November 2023 at 16:18 #50621XavierItzmann
BRONZE MemberGot it. Thanks again, MM!
