Home Forums Product Discussion & Questions BeoSound Essence MK1 main unit
  • #72063
    beophase
    Hi Beoworld,
    can this device be used like an Beolab-RCA connection extender? So it will swtich on a connected Beolab speaker connected via PL if a signal is detected on RCA input? Im looking for extact that feature.
    Thanks in advance!
    #72064
    Guy
    Hi and welcome to Beoworld!
    The answer is ‘yes’ – the RCA line-in has auto-sense which will trigger the PL and Beolabs.  You may well have to set up autosense (sensitivity etc) in the menu, accessible from most browsers or the B&O app.  You will also have to set up whether the output should be fixed volume or controllable (via remote or B&O app).
    beophase
    Quick response! Thank you motoGuy.
    Im no new member but a very quiet one. ;]
    Are there more optional devices with that feature, besides the Beosound Essence MK1 and MK2 you know of?
    #72066
    Guy
    Ah, I should have checked – you registered nearly 4 years ago, and may well have been on the old forum too!
    Here’s another device that will carry out the same function:  https://shop.oneremote.dk/shop/69116-powerlink-aux-adaptor/
    Or you could look for a second-hand B&O Playmaker – they have auto-sense on the aux input:  https://bangolufsenassistentgohe.blob.core.windows.net/manuals/SOUND_SYSTEMS/PLAYMAKER/UG_Playmaker_EU_US_current.pdf
