Home › Forums › Product Discussion & Questions › BeoSound › Essence MK1 main unit
- This topic has 5 replies, 3 voices, and was last updated 3 months ago by
matador.
23 December 2025 at 08:11 #72063
beophase
BRONZE MemberHi Beoworld,
can this device be used like an Beolab-RCA connection extender? So it will swtich on a connected Beolab speaker connected via PL if a signal is detected on RCA input? Im looking for extact that feature.
Thanks in advance!
23 December 2025 at 10:34 #72064 GuyModeratorHi and welcome to Beoworld!
The answer is ‘yes’ – the RCA line-in has auto-sense which will trigger the PL and Beolabs. You may well have to set up autosense (sensitivity etc) in the menu, accessible from most browsers or the B&O app. You will also have to set up whether the output should be fixed volume or controllable (via remote or B&O app).
23 December 2025 at 14:03 #72065beophase
BRONZE MemberQuick response! Thank you motoGuy.
Im no new member but a very quiet one. ;]Are there more optional devices with that feature, besides the Beosound Essence MK1 and MK2 you know of?
23 December 2025 at 15:54 #72066 GuyModeratorAh, I should have checked – you registered nearly 4 years ago, and may well have been on the old forum too!
Here’s another device that will carry out the same function: https://shop.oneremote.dk/shop/69116-powerlink-aux-adaptor/
Or you could look for a second-hand B&O Playmaker – they have auto-sense on the aux input: https://bangolufsenassistentgohe.blob.core.windows.net/manuals/SOUND_SYSTEMS/PLAYMAKER/UG_Playmaker_EU_US_current.pdf
23 December 2025 at 19:04 #72069beophase
BRONZE MemberMy first registration is older then that, but not of any importance.^^
Thanks again, very helpful!
24 December 2025 at 13:16 #72077 matadorModeratorHi, I’d like to add that Autosense in my Playmaker is a little bit wobbly in my case: Airplay start do work. Line in do work. But cross switch do not work at all.
If I’ve use line in then Airplay Auto sense doesnt work anymore. Nor if I stop Analogue in nor if it is just hjiacked with an airplay signal. I need the to select the entries with the remote.
Maybe a local issue but needs to be said if your use the Playmaker in heterogenous setup.
Cheers.
