Home › Forums › Product Discussion & Questions › BeoVision › Eclipse MKI with LG C3 Oled
- This topic has 12 replies, 7 voices, and was last updated 1 year, 1 month ago by
Robert.
2 August 2023 at 01:44 #48019
Mbee
BRONZE MemberHi,
I’ve got an Eclipse MKI with a broken LG (C7) panel. B&O is asking 2600€ for a panel replacement (they keep the C7 TV and change the panel inside).
But when they were here, the B&O technicians said it would be possible to just exchange the 55C7 with a brand new 55C3 for less money (in fact, it’s 1000€ less!), but now they say it’s only on mkII Eclipse…
So is it possible or is there something preventing me from doing this?
Software-wise, the technicians said that the B&O app is available on the C3, so I should get the stand and Beoremote working, and all the settings for the beolabs… and if there is something locked to a C7 panel on the MKI, the difference of the panel may buy me an Eclipse MKII motherboard that should solve the problem…
Mechanically, either the old screen mount is still compatible with the screw positions of a C3, or I should order just this part from an Eclipse MKIII, or eventually I have to make a custom DIY screen mount.
Any advice or suggestion? Maybe somebody here already did such a conversion…
3 August 2023 at 09:20 #48020Mbee
BRONZE MemberI’ve got new feedback from B&O headquarters.
For them, it’s not possible for 2 reasons, but the reasons doesn’t seem to be valid :
- Mechanically the cutout is different : of course, but as I said, as the newer panels are smaller, they can fit, there will just be a gap…
- Eclipse Gen 1 doesn’t support eARC : here I can’t understand, as the only way to connect the soundcenter to the C7 panel is to use the HDMI2, its only ARC HDMI input ! The Eclipse mkI already used ARC, and eARC is retrocompatible with ARC speakers…
3 August 2023 at 13:22 #48021Mbee
BRONZE MemberIf nobody has ever tried… My dealer (who is multibrand) proposes me to test with his demo 55C3. I’ll keep you informed, but if somebody knows that it’s not possible, don’t hesitate to react!
13 August 2023 at 21:43 #48022Msinn
BRONZE MemberI am having an Eclipse MkI 55″ with screen burn too. I would be interested in your results
14 August 2023 at 20:09 #48023Ingo
BRONZE MemberMy Eclipse MK1 also with burn-in.
Replacement would have cost a good 1500€.
I have written to several dealers. Another panel can not be used because the Soundcenter MK1 can not be controlled with the B&O app.
I then decided on LG OLED G3 combined with the Theatre.
TV has 5 year warranty, new panel already after a few weeks get.
But very slow spare parts supply, waited about 4 weeks for it.It was a costly experience for me.
I scrapped the panel and have the sound center well packed in the basement. 8 months left, then I’m retired, then I’ll have the time to reactivate the soundcenter.
Replacing the mainboard is a good approach, but you can also get into the speaker menu via an IP address, maybe something can be done.1 March 2024 at 20:41 #48024Toma48
BRONZE MemberAny feed back on this ? It appears every tv has done the same and B and O s answer to the problem is give another faulty panel , I’d love to know if the c3 worked with the mk1 eclipse
3 March 2024 at 13:05 #48025Mbee
BRONZE MemberI can confirm, LG C3 on mkI Eclipse Soundcenter works, with a bit of diy work (homemade brackets, that’s all). Futureproof not guaranteed but Soundcenter MkI is using HDMI ARC so quite standard.
13 March 2024 at 22:02 #48026johnjohnny
BRONZE MemberHi Mbee, I’m in a similar situation to yours.
I have got an Eclipse MK1, bought in early 2020; the TV was turned off for 8 months because I moved to a new town, 2 weeks ago I moved the TV in the new home but now it has some troubles. The TV doesn’t stay on, it powers off intermittently; in addition two vertical lines of pixels remains completely black.
I brought the TV to B&O service; to restore the TV I have to replace the motherboard, for switching off issue, an the panel, for the black pixels, for a total expense of 2400 €.
Could you explain in details what you did to mount the C3 TV on the eclipse? Do you have pictures of the result? Do all original functions works correctly?
Thank you
27 October 2024 at 17:05 #60488Toma48
BRONZE MemberHi buddy , spoke to you a while back about eclipse mk1 you got working with different panel you got working , I’m having a hell of a time trying to sync a G4 to my mk1 eclipse . At first it sort of worked as on sound passed thew of but down loading that app didn’t turn it into a b and o tv . I still had to come out the app and on to lg home menus to go into Amazon apple and so . Is this how yours works or have I not don’t it properly . Cheers Thomas
31 October 2024 at 21:09 #60619Oim1212
BRONZE MemberDid anyone get a clear answer if it works or not?
31 October 2024 at 21:24 #60622Mbee
BRONZE MemberWorks, only issue is that you don’t have mybuttons configuration available.
31 October 2024 at 21:31 #60623Oim1212
BRONZE MemberSo everything else works? And which screen do you use? Does it fit directly ? Can you add speakers ass surrounds and all the other wisa settings. Do the B&O app on the newer tv recognise the old sound centre? Sorry for all the questions. But need to know before a purchase in about to do. 🙂
15 January 2025 at 14:32 #62694Robert
BRONZE MemberSTB Brackets have a solution for upgrading the Eclipse MKI to LG C2, C3, and C4:) They have removed it from the shop for now – they write that they are working on a better upgrade together with B&O for the MKI. Good news!
https://www.stbbrackets.co.uk/product/beovision-eclipse-lg-c4-upgrade-adapter/
