Home Forums Product Discussion & Questions BeoVision Eclipse 1st gen-no B&O app in LG Content store..
  • This topic has 4 replies, 2 voices, and was last updated 2 years ago by zebe.
  • #52852
    zebe
    Hello guys,
    Just inherited TV Eclipse and a pair of Beolab18.
    Everything great but after moving from Bornholm to Poland, connecting TV to internet
    it proceeded w/auto firmware update => factory reset.
    There is no B&O tv app in LG Cotent Store, no matter if I set location to Daenmark, UK, Poland whatever.
    Does anybody have any idea how that app should be installed??
    cheers,ZZ
    #52853
    YannChris
    GOLD Member
    If I well remember, the 1st Gen Eclipse does not need the B&O app from the LG Content store.
    Settings are manage through the TV menu. You need to press the “house-shaped” key of your remote, then go to the settings icon.
    Yann.
    zebe
    Hello Yann,
    Thx for quick response.
    The problem is HOME button on Beoremote ONE/BT/ is INACTIVE, ie does not produce any action on the TV…
    #52855
    YannChris
    GOLD Member
    Hello,
    Did you pair the Beroremote to the TV?
    Here is the process:
    https://support.bang-olufsen.com/hc/en-us/articles/360042302032-Remote-control
    In addition, you can find the only user guide available here:
    https://support.bang-olufsen.com/hc/en-us/articles/360041518952-Beovision-Eclipse-1st-Gen
    zebe
    Hello, sure but not through HOME button but rather TV->Settings and cursor/arrow keys on the remote etc etc.
    HOME is inoperative.
    Btw I got no Sound&Beolink menu option…,
    And -yes-
    a) did every possible reset/factory reverting.
    b) did both TV and Beoremote software update.
