Home Forums Product Discussion & Questions BeoLab DIY Beolab 8000 Wood frets (STLs included).
Viewing 20 posts - 121 through 140 (of 180 total)
  • #36903
    egru123
    Hello BramBoerema
    there is no difference in the housing between BL 6000 and BL 6002. BL 6002 uses modified Bass-Mid-Drivers. There are many people around here who really do appreciate when you design the clamps and share the STL File/s with us – me too 🙂
    thanks in advance
    #36904
    cgh
    Acoustic lense
    I designed an acoustic lense that will fit on top of the BL 8000, Attached is the stl file.
    Thank you for the clips for the BL 8000, it is very appreciated.
    I tried to upload the stl file, but it seems not to working??
    #36905
    egru123
    Thanks cgh providing the stl File. I used the Extension PDF and the upload works. Caution everybody: the attachment is a stl file (and not a pdf) thanks again cgh
    #36906
    wol0977
    Excuse me for the offtopic!
    For all the guys (me included) who are looking for the clamps for the 6000:
    Since I couldn’t find the 3D files anywhere, I may have an alternative for you.
    The fabric of my 6000 had tears and didn’t look good anyway, so i removed it.
    As you can see in the attached pictures i simply glued wood sticks on the metal grill and it looks good to me.
    the costs:
    EUR 6,5 for the wood
    EUR 12 for the color (light oak)
    EUR 5 for the double adhesive tape (transparent)
    optional: EUR 10 for the transparent matte paint spray to fix the color
    #36907
    YannChris
    FOUNDER Member
    Hi Matador,
    Copycat? Check here:
    https://www.leboncoin.fr/photo_audio_video/2509547503.htm
    My B&O Icons: No description available No description availableNo description availableNo description availableNo description availableNo description availableNo description availableNo description availableNo description available No description available No description availableNo description available No description available
    #36908
    matador
    Hi Matador, Copycat? Check here: https://www.leboncoin.fr/photo_audio_video/2509547503.htm
    Hi YannChris,
    Thank you for the heads-up.
    There are a lot of copycats around including people who just sell the clamps I design with the Ikea like manual but this one is not. It may be inspired but it’s not the same, it is deeper and rounder.
    #36909
    Manulito
    Can someone tell me if he has a file for the Beosound 9000 to equip it with the wood cover? Also I try to build a cover for my Beolab 1 but struggle to identify the best position for the clamps. Anyone has some experience for the best position?
    #36910
    MVee
    MVee
    I live in The Netherlands and no 5mm slats are sold here either. So I bought 4mm slats. 4x18x2100: Which I had custom made by the wood trade to 4x13x1000 (and then a total of 28 slats for one set of BeoLabs) 4x44x2100: Which I sawed myself in a length of 1000mm (a total of 2 slats needed for one set of BeoLabs)
    Did you use oak wood? I live in The Netherlands as well. Which wood supplier supplied them in the rights dimension? Have a hard timing finding the right (oak) wood. Thanks for you hints!
    #36912
    MVee
    When I look at your STL file, I see room for 10 wooden slats, but I see a slightly longer piece on one outside and an extra notch or something like that on the other outside? The 7.1 STL doesn’t look the same as your own photo’s in your first post:
    Did you already try on a 7.1 or 7.2? Are the clamps equal? And how does the result look?
    #36913
    catch
    Do you have the file for the lens?
    #36914
    catch
    Acoustic lense I designed an acoustic lense that will fit on top of the BL 8000, Attached is the stl file. Thank you for the clips for the BL 8000, it is very appreciated. I tried to upload the stl file, but it seems not to working??
    #36915
    Mikaeln1
    For the poor Australians out there who haven’t got a beautiful selection of European wood frets available here’s what I did 🙂
    They look amazing btw and thank you for this thread to modernise the appearance
    frets
    #36916
    cgh
    Egru123 uploaded the file for me. Please see the post from him
    #36917
    Bwel
    Has anybody found a good supply for the 4mm Stripwood pieces in the U.K. ?
    Many thanks,
    #36918
    Bwel
    What lengths of Stripwood are people using ?
    I see the design sheet here say 100cm, but other people have suggested 105cm.
    I’m not sure what looks best ?
    #36919
    mohcineamrani
    Hi all, while checking the 3d file i have doubts on measurements, see picture below (X, Y, Z)
    thank you
    mohcine
    #36920
    matador
    Please guys having “doubts”…
    Read the thread carefully, there are of course scale errors; x10, x1000, x100, whatever…
    Just think!
    Plenty of people have sorted it out and successfully made them better than me.
    This is an enthusiast forum, not an after sales hotline.
    With all due respect.
    #36921
    matador
    […] goto Bunnings…
    Let me invite you “poor Australian” to our European “Leroy Merlin” in exchange to you inviting me to Bunnings!
    Nice work and happy to have helped…
    #36922
    Mateki
    Thank you matador for sharing
