Home Forums Product Discussion & Questions BeoLab Most popular topics
Viewing 20 posts - 61 through 80 (of 182 total)
  • #36843
    tuttivini
    @matador Wouldn’t it be better looking if you also design/print (with black PLA/PETG/ABS) the top panel instead of using piece of black cardboard cut to shape?
    Would it be possible to add this to the design?
    What thickness (in mm) would give us the best/flush look?
    top cover
    #36844
    matador
    @matador
    Yes it maybe would be. The thing is I dont undertsand anything in PLA/PETG/… plastics and I rely on an remote 16, hormonal dependent teenager for the printings. Then as soon as the wood grills were on the speakers I stopped research!
    #36845
    drmichi
    You might have a problem to 3D print a nice and smooth surface, for sure you need to grind and paint it afterwards. I also used the black paper as a quick fix 🙂
    I personally wouldn’t go for a flush top panel, since the design really adds some nice details if the wood covers are 2mm up, but still lower than the chrome head.
    #36846
    stivenmar2
    hi mate can you make me those 3d Plastic wood holders for two speakers will pay you of course   ,because i don’t have 3d printer the rest of the work will do it by my self thanks let me know please ha e a good one
    #36847
    sharknm
    Thanks for these. It is just amazing. Can please someone do it for 6000’s?
    #36848
    sprockett
    Hi @matador!
    May i know the difference btw the 5mm files and the 4mm files?
    #36849
    matador
    The 4mm clamps are designed for 4mm thick wood bits.
    The 5mm clamps are designed for 5mm thick wood bits easier to find in nothern countries it seems.
    #36850
    sprockett
    @matador
    I was comparing them and it appears the “curve” is smaller and flatter on the 4mm vs the 5mm?
    Does this mean visually it will look like a bigger and more curved?
    #36851
    matador
    The 5mm model was developed by another member from my design, to fit local wood supply so I can’t really say. Nevertheless, there is indeed a strong link between curve, depth, wide, number of lamellas and their thickness, so it make sense the curve is more important.
    And yes it will result in a less thinner speaker. To what extend ? I dont know.
    #36852
    jesnystrup@gmail.com
    Hi everybody..I need help  ..i have a question ..What is the true size of the top lid in the pdf document ..
    I cant get it to work on the printer since its a long pdf doc ..I cant get the scaling right so if anybody have a stl or size doc for the normal printer or 3d printer or the laser file for the cutter can you please share it
    Thanks.
    #36853
    tuttivini
    What kind of ‘brackets’ are used on the beolab 8000 on this picture (the right one)?
    This one hasn’t got a top-plate, so looks more like the original beolab 18. I like this al lot!
    IMG_20230320_202928
    #36854
    matador
    It’s not about the brackets, it’s about the lamellas. They are rounded and must be L shaped at the top. I think they’re also very thin (not deep). All this to say that this solution involves a lot of woodwork and is certainly not 50€. But indeed the result has nothing to compare with my cheap solution.
    #36855
    tuttivini
    You discovered the secret! I think you are correct. The lammellas have a L-shape on top. Looks good, but indeed a lot of woodwork…
    I’m going to print your brackets next week and buy all the needed wood. We are going to make 2 sets. For my dad and for myself.
    #36856
    tuttivini
    Hi all Here in Denmark it seems that 5mm frets are more easily available. I have therefore created clamps based on 5mm frets. I have created new STL files based on Matadors original clamp design, but slightly changed. They are 5mm wide, a litte deeper in the groove and more curved. There is also 3 clamps now. A Top, Middle and Buttom. The Top and Middle clamps rests on the speaker structure – and the Buttom just floats. You can choose to replace the Middle with the Buttom clamp if you wish. The clamps were made in Fusion 360. I have provided both the Fusion 360 files and the STL files. That way you can adjust the clamps to your specific needs if needed. Credits go to Matador for starting this. He also approved to add the files here.
    @Lemme
    : Do you have pictures of beolab 8000’s with your 5mm brackers/final result looks?
    I’m interested in how it looks compared to Matadors 4mm brackets, because the ‘curve’ looks smaller on the 4mm brackets…
    #36857
    tuttivini
    @matador Why are the slots in the 4mm only ~2.2mm deep?
    Is this enough to ‘clamp/hold’ the lammellas firmly?
    #36858
    matador
    At first they were meant to be a cradle to hold the sticks with a drop of glue.
    But in the end the sticks did click in and stay firmly in place without glue.
    The groove is not deep to stay invisible between the lamellas.
    #36859
    jackie0
    Hi Matador and community,
    Thanks a million for sharing and uploading the files, this is amazing.
    Not knowing anything about 3D printing I sent the STL files to a local printer. He says that the files do not have any measurements.
    @styppen
    asked the question before and was also kind to share mm measurements for x,y and z. But what do these represent?
    Could someone please advice how I communicate the measurements to the printer?
    Many thanks in advance and apologies for perhaps asking a stupid question.
    Best regards from Sweden
    J
    #36860
    matador
    The screen capture and measurement from styppen are right.
    It’s the “bounding box” size of the whole object.
    For whatever reason my export do not carry scale information and you have to scale it depending on your printer device. But it should usually be a round factor: x10, x100, x1000.
    Anyway, give your supplier the bounding box size and it should work.
    #36861
    kronzilla
    Looks very nice. I discovered, the chrome speakers looking much nicer with the wooden frets. Wirh the black covers they looking outdated. I have a black pair and that pair looks good with the original covers.
    How can i obtain the files to make the fronts? I don’t know nothing about 3d printing but gonna ask a friend.
    #36862
    The files are here on this thread on page 1
