Home › Forums › Product Discussion & Questions › BeoLab › DIY Beolab 8000 Wood frets (STLs included).
- This topic has 179 replies, 82 voices, and was last updated 1 month ago by
Samuel Vesterlund.
21 September 2022 at 11:37 #36824Moderator
i have one speaker done and it looks wonderful.
That’s great work, thank you for sharing it!
Location: Paris France11 October 2022 at 05:27 #36825mojofml
BRONZE Membersorry disregard, just realized you’ve already addressed a wisdom relating to beolab 6000 above
17 October 2022 at 23:52 #36821ModeratorYes it is.
Location: Paris France29 October 2022 at 16:02 #36826kronzilla
BRONZE MemberYou are right it looks much better than the very expensive ones (indeed too wide and bulky) and your solution is also alot cheaper
3 November 2022 at 22:05 #36827beodane
BRONZE MemberThx for sharing 🙂
11 November 2022 at 12:23 #36828Pit
BRONZE MemberWonderful idea and great realization. Thanks very much!
Peter28 November 2022 at 14:20 #36829BeoT
BRONZE MemberMany thanks for sharing, keep up the good work
1 December 2022 at 23:29 #36830gerard
BRONZE MemberThank you for sharing your project an the STLs.
The frets of my BL8000 have to be redone, I already have the fabric from Akustistoff, but new ideas come up to me 😉
Merci beaucoup!
9 December 2022 at 19:49 #36831RosenRot88
BRONZE MemberHi guys
Something wrong with STL file. When I import in cura or other slicer. dimensions are small, like 2mm in hight small. Also STLs in folder are corrupted and wont open.
Can you resend files please
Thanks and regards
9 December 2022 at 20:16 #36832ModeratorHi guys Something wrong with STL file. When I import in cura or other slicer. dimensions are small, like 2mm in hight small. Also STLs in folder are corrupted and wont open. Can you resend files please Thanks and regards
Read the whole thread. depending on your software you may need to scale it by 10’s factor.
The STL’s have been checked tonight and look ok. Given no other member have report problem and some have even already printed them, I let you investigate from your side.
Regards.
Location: Paris France12 December 2022 at 10:15 #36833Lemme
BRONZE MemberHi Matador
Is it possible for you to provide the original design file from the application that you used to create it with. Like Fusion 360, SketchUp or Tinkercad.
The reason is that I need to modify the model as the most used wooden frets here in DK are 5mm.
12 December 2022 at 11:05 #36834ModeratorHi Lemme,
Once the STL generated I didnt kept the original 3D file (which was Cinema 4D BTW).
But I think you can “de-construct” the .STL file, I’ve checked it with CAD Assistant and all the parts are visible and do not look like merged.Actually, adjusting the witness of the slots is the worst and more complicated part of the whole design, at least with the tools I had at hand. So the slots were roughly designed flat with… the dashed line tool in a vector design software (!), adjusted to be centered and then extruded in 3D. I remember that adding a slot, adjusting the size of it or moving them one side or another made instantaneously a mess.
My advice if I may: use your 5mm wood fret, mark where the touch the clamps and correct the witness with a file just on the rear part of the lamella. I had to do this for two or three sticks that were beyond tolerance (wood is sold for 4mm +/- 2%).
Location: Paris France12 December 2022 at 11:29 #36835Lemme
Thank you for a very swift response!I can follow your trouble with creating all the wide slots in the correct angle – it must have been taken a lot of trial&error to get right.
As you sugget, I will try with CAD Assistant or similar tool first. If that do not work then you are right, I must adjust the wooden frets with a file.
Many thanks for you contribution!
6 January 2023 at 11:15 #36836Lemme
BRONZE MemberHi all
Here in Denmark it seems that 5mm frets are more easily available. I have therefore created clamps based on 5mm frets.I have created new STL files based on Matadors original clamp design, but slightly changed. They are 5mm wide, a litte deeper in the groove and more curved. There is also 3 clamps now. A Top, Middle and Buttom.
The Top and Middle clamps rests on the speaker structure – and the Buttom just floats. You can choose to replace the Middle with the Buttom clamp if you wish.
The clamps were made in Fusion 360. I have provided both the Fusion 360 files and the STL files. That way you can adjust the clamps to your specific needs if needed.
Credits go to Matador for starting this. He also approved to add the files here.
6 January 2023 at 12:40 #36837ModeratorI’ll add all the files to the first post.
Location: Paris France11 January 2023 at 17:42 #36838swo
BRONZE MemberDid somebody found a drawing for Beolab 6000 ?
thx
17 January 2023 at 13:07 #36839filipbrugge
BRONZE MemberWaw, I did it and looks great. Thank you for sharing !
Did someone manage to do it for the beolab 6000 ?
I would really like to do the same on them.
Greetings from Belgium
17 January 2023 at 21:11 #36840drmichi
BRONZE MemberThank you so much for sharing!
22 January 2023 at 10:02 #36841drmichi
BRONZE Member22 January 2023 at 10:34 #36842ModeratorThank you drmichi for showing us your work.
Nice shade of wood and beautiful Beocorner you have there.Enjoy.
