Home › Forums › General Discussion & Questions › General Discussion & Questions › Datalink on Beogram Turntable
- This topic has 9 replies, 6 voices, and was last updated 1 year, 6 months ago by
Weebyx.
30 August 2024 at 13:08 #58719
spassmakerBRONZE MemberMy question is if the Beogram 4004 would interact with an Beomaster 6000 ( not 4CH) or Beomaster 8000?
Thanks for advice.
Kind regards
Christian
30 August 2024 at 15:02 #58720 GuyModeratorAs far as I know it would work with both. I have had a read of this and cannot see any limitations for either of those setups mentioned: https://beoworld.org/datalink/
30 August 2024 at 15:35 #58721Madskp
GOLD MemberThere are mentioning of some limitations in the datalink implementation in the Beomaster 6000 here https://beocentral.com/beomaster6000-1980s
If I understand it correctly its about starting the Beomaster from the control panel on the Beocord, so should not interfere with remote control of a record player
30 August 2024 at 17:44 #58730mcevedy@mac.com
GOLD MemberNot convinced it will work though will try it out when I can. The 4004 used a proto datalink and Tim on Beocentral suggests it is not compatible. I will let you know – will need to find where I put the spare DIN pins first!!
The Beoworld piece also suggests that it will not work remotely. It will of course function perfectly well as a record player – I have used mine with all sorts of Beomasters.
30 August 2024 at 18:55 #58740Madskp
GOLD MemberThe text on Beocentral i pretty clear that it will only work with a Beomaster 2400-2 https://beocentral.com/beogram4004
Furthermore looking at the diagram for the Beogram 4004 I can see that the data connection use both pin 6 and 7 where normally pin 6 is used for Beograms without Riaa built in and pin 7 for Beograms with RIAA built in
31 August 2024 at 07:51 #58748Dillen
ModeratorIt will not work.
The “old” and “new” datalink systems are not compatible.Martin
31 August 2024 at 11:52 #58751 GuyModeratorIt will not work. The “old” and “new” datalink systems are not compatible. Martin
Thanks @Dillen (and everyone else). I agree despite my earlier incorrect post!
I have just been revisiting my Chrome history to try to work out why I thought otherwise. I did see a paragraph taken from a ‘Beolink’ article the old forum which stated: The idea of electronic sensi-touch controls did away with old-fashioned buttons and other mechanical ways of controlling your equipment and paved the way for the first true ‘Datalink’ product: Beogram 4004. Clearly I took this too literally and didn’t investigate further, or even read fully the ‘datalink’ page that I linked – many apologies.
@Peter – no need to run the test! 😀
3 October 2024 at 11:35 #59726Weebyx
BRONZE MemberI have made this 🙂
It is making the BG4002/4004 act like a BG7000 with the modern Datalink beomasters.
/Weebyx
3 October 2024 at 15:31 #59742mcevedy@mac.com
GOLD MemberVery clever! It amazes me how resourceful members are! I confess that I always clean the record before playing it as usually use a 20CL and any dust simply collects on the needle. And my best deck is completely manual. However clearly there will be demand though maybe a non RIAA version could also be popular.
4 October 2024 at 08:55 #59778Weebyx
BRONZE MemberVery clever! It amazes me how resourceful members are! I confess that I always clean the record before playing it as usually use a 20CL and any dust simply collects on the needle. And my best deck is completely manual. However clearly there will be demand though maybe a non RIAA version could also be popular.
It is possible to bypass the internal RIAA 🙂
