Home › Forums › Product Discussion & Questions › BeoSound › Cover art issue on Beosound 5/Beomaster 5
- This topic has 5 replies, 2 voices, and was last updated 2 years ago by
XavierItzmann.
26 March 2024 at 09:30 #53823
Paolo
BRONZE MemberHi, I have a bs5 and BM5. I’ve sucessfully connected it to my pc using beoconnect, but when i try to import songs (WMA) to the hdd of the BM5 the album cover is distorted, and i’ve put a 1000×1000 pr 600×600 image.
can anyone help?26 March 2024 at 21:32 #53824Paolo
BRONZE MemberAnother thing i’am using Windows media player to ripp my cd’s in quality WMA lossless
26 March 2024 at 22:36 #53825XavierItzmann
BRONZE MemberOn my system, I always use images that are perfectly square. I may have made an exception or two and imported for instance 500×499 once —maybe twice— only because I was not able to find anything else on the internet.
I add the images to the songs using iTunes (also known as Apple Music).
The representation on the BS5 is always that of a perfect square, using this procedure.
26 March 2024 at 22:54 #53826Paolo
BRONZE MemberAnd how do I do it?
26 March 2024 at 23:02 #53827Paolo
BRONZE MemberBut the thing is that I can put the image, and it appears on the Beosound 5 screen, put it appears distorted (like in low quality) eaven if I saved a 1000×1000 album cover
27 March 2024 at 15:41 #53828XavierItzmann
BRONZE MemberI am not familiar with Windows Media Player.
On iTunes, here is how I do it: once I have extracted the music from the CD and iTunes has completed all of the metadata, I select all the songs in the album and ⌘i (command-I), which is equivalent to the menu item > Song > Get info…
On the dialog window which appears, I select the tab “artwork”. And then I choose “Add Artwork” and select the square image I have saved somewhere in my disk.
It works perfectly every time.
