Home › Forums › Product Discussion & Questions › BeoVision › Connecting Beosound 9000 via Beolink to Beovision Avant 85
- This topic has 3 replies, 3 voices, and was last updated 3 years, 2 months ago by
carolpa.
10 January 2023 at 05:06 #42683
armit
BRONZE MemberGreetings,
Please advise how to connect and setup this chain of devices. I connected the Beosound 9000 to the BeoLink Converter NL/ML with the MasterLink cable, but I am not sure which RJ45 ports need to be used to connect the Beolink to the Avant TV set (both sides).
Second question is about the setup of TV set. What steps of the TV Menu to follow to set-up use of Beosound 9000 via Beolink?
Many thanks
10 January 2023 at 23:21 #42684 MillemisBRONZE MemberYou should be able to find the answer to your questions (and more) here:
https://cdn.webshopapp.com/shops/98396/files/334286248/beolink-converter-nlml-ver-14-beomac.pdfMM
11 January 2023 at 00:30 #42685armit
BRONZE MemberMany thanks! Will give it a try!
11 January 2023 at 14:01 #42686 carolpaBRONZE MemberYou should be able to find the answer to your questions (and more) here: https://cdn.webshopapp.com/shops/98396/files/334286248/beolink-converter-nlml-ver-14-beomac.pdf MM
the difficulty is how to integrate the BS9000 with the Avant and how to start the BS9000 with a remote and/or B&o app. Not all devices are compatibel.
if the Avant is not an Android version, it is possible to connnect,
if Armit has another NL-device in his Network the solution would be obvious,
if an IR eye and speakers are connected to the Beolink converter NL/ML (BLC) it should be possible. -
