Home › Forums › General Discussion & Questions › General Discussion & Questions › connecting beomaster 7000 home network via Fritz box
- This topic has 1 reply, 2 voices, and was last updated 6 days, 13 hours ago by
T.W.G.
13 October 2026 at 10:05 #125871
andrewl
BRONZE MemberHi. I as wondering if there is something that I could buy which would enable me to link my beomaster 7000 to my home network? Id love it if I were to be able to put a CD on in the sitting room and have it streamed to my apple home pods. Thanks.
27 October 2026 at 08:50 #126109 T.W.G
GOLD MemberUnfortunately Apple closes and locks down everything, so there’s no easy solution to achieve that. While home pods have Bluetooth integrated it is locked down by Apple for every device to send audio to it.
There’s a workaround to achieve external Audio:
An application called “AirChord” which requires (of course) an iOS-Device and an Line-In Adapter. You then connect your Beomaster to this combo and can use the app to stream your Beomasters Audio to the home pods.recommended adapters: https://www.airchord.app/hardware/
https://apps.apple.com/us/app/airchord/id1343901847
If you have a Mac running I assume that you can send any Line-In audio signal to the airplay network from the Mac!?
