Home › Forums › General Discussion & Questions › General Discussion & Questions › Connecting a Beocentre to a phone
  • #64477
    Chris Townsend
    I’ve purchased a Beocentre not sure which one(doesn’t have a tape player) and I’m trying to connect my son’s phone to it. Do I purchase a Beolink to female mic cable? I’ve got a Bluetooth receiver already.
    Any ideas as to what I need and where from?
    #64479
    Millemis
    Is your bluetooth receiver already connected to the ‘Beocentre’?
    If yes, how and which ‘button’ is used to activate the input?
    (Do you use a remote for the ‘Beocentre)?
    If yes, push that button and let him connect to that with his phone….he can find the receiver in the bluetooth settings there.
    Note: you/he will have to turn up the volume on the phone to almost max and then control the volume on the ‘Beocentre’.
    #64480
    Guy
    What output connection does the Bluetooth receiver have?  If you can described that or post a photo (and one of the Beocenter!) we can suggest a suitable cable.
