Home › Forums › Product Discussion & Questions › BeoGram › Connect Beogram 4400 to a CD Player
- This topic has 4 replies, 3 voices, and was last updated 3 years, 8 months ago by
pnapoleao.
27 July 2022 at 03:25 #36394
pnapoleao
BRONZE MemberHi everyone,
I have a Beomaster 4400 and a Beogram 1700 that I’ve inherited, that are working perfectly. I linked a Chromocast audi using a Sounds Heavenly cable, and I’m very happy with the system.
However, I miss to listen my CDs. I wandt to buy a vintage Beogram CD player but not sure which model will be able to connect to the Beomaster 4400.
Any advice?
Thank you.
Patrícia
27 July 2022 at 16:03 #36395 Millemis
BRONZE MemberAs far as I remember the BM4400 has 5-pin input connections (one for Phono and two for Tape).
Basicly you can use any CD player – in some cases you’ll have to use an adapter (R/L to DIN).
If you want vintage B&O….go for a CDX/CDX2 – which one is better the vintage specialist here may tell you.
There you have options for controlling directly on the device.
27 July 2022 at 16:17 #36396pnapoleao
BRONZE MemberThank you so much!!
27 July 2022 at 16:51 #36397 Steve at Sounds HeavenlyGOLD MemberHi Patricia,
Welcome to BeoWorld! Glad to hear that the cable I sent for the Beogram is working well.
You just need this cable to link any non-B&O CD player to the Tape input of the Beomaster as MM mentioned, this is the cable you need:-
Any questions, please ask!
Kind regards, Steve.
27 July 2022 at 16:53 #36398pnapoleao
BRONZE MemberThank you once again Steve!
