Home › Forums › Product Discussion & Questions › BeoVox › Changing fabric on Beovox S120
- This topic has 9 replies, 3 voices, and was last updated 3 years, 8 months ago by
sonavor.
26 July 2022 at 01:11 #36345
Mark2000
BRONZE MemberMy 2400s were shipped to me damaged years ago. Recent I thought I might like to replace the fabric on the outer covers. At first I thought poking these little holes might pop the plastic sandwiching the fabric off one another, but I’m not sure that’s the case. Anyone know how to preform this surgery? Do you need to remove the metal frame? If so, how? I’d love to have intact speaker fronts for once. Thanks!
28 July 2022 at 06:21 #36352sonavor
BRONZE MemberHere is a link to the page on the old forum.
It was on a post I did restoring some Beovox MS-150 speakers. They are larger but have the same cabinet/grill design as the S120’s.
The photos – beovox_ms150_grill_00.jpg, beovox_ms150_grill_01.jpg, beovox_ms150_grill_02.jpg and beovox_ms150_grill_03.jpg show the different stages of the grill disassembly.The disassembled photo at the end shows the successful removal of the aluminum trim with it still intact.
-sonavor
28 July 2022 at 06:41 #36346Dillen
ModeratorThe fabric is held by the alu trim. You can ease the trim out carefully.
And they don’t look like Beovox 2400.
28 July 2022 at 07:10 #36347Mark2000
BRONZE MemberMy mistake, I got confused with my beomaster. They are S120s. So, I get the fabric out from between the metal and the plastic. How do I get new fabric back in?
28 July 2022 at 07:46 #36348Dillen
ModeratorYou get the new fabric in the same way. Pressed in using the alu trim.
Clever? Yes.
Elegant? Yes.
Easy? No.I have had a little success first glueing the new fabric in to the ridge on one side,
then, when set, work to the opposite side etc. and fit the alu trim last.Martin
28 July 2022 at 15:28 #36349Mark2000
BRONZE MemberOk. Let me see if I understand…
Pull the fabric out from between the metal and the plastic. That frees the metal trim and let’s you take it off completely
Glue on new fabric to the edge
Replace the metal trim on top of that.
Did I get that right?
28 July 2022 at 16:50 #36350Dillen
ModeratorNo. First take off the alu trim. The cloth is held in the ridge for the alu trim.
28 July 2022 at 18:06 #36351sonavor
BRONZE MemberI have a post on the old version of the forum that shows doing that.
I will try and find it and post the link.
You have to be very careful with the aluminum trim and just bend it a minimum amount to release it. Otherwise, bending out straight will most likely cause the trim to break off at the bend seam.-sonavor
28 July 2022 at 23:01 #36353Mark2000
BRONZE MemberWow, Sonavor. Thank you for the images. I really understand the process now. We’re you able to bend the aluminum back to the original shape? I would image it would never go completely back.
30 July 2022 at 06:52 #36354sonavor
BRONZE MemberYes, as Martin mentioned earlier, the aluminum frame piece wedges the grill cloth in place. They should fit nice and snug in the plastic frame just like the original was.
-sonavor
