Home › Forums › Product Discussion & Questions › BeoGram › CDX low and weak output
- This topic has 3 replies, 3 voices, and was last updated 3 years, 3 months ago by
PeterL.
29 November 2022 at 12:28 #41144
PeterL
BRONZE MemberHi all. I am new to this forum and I am currently working with a CDX for a friend.
The cd could not be read by the player but by following advice from this forum I re-soldered the vias and now it reads ok. However, the output is very low and the sound is a bit weak and bright. I did not replaced any capacitors but before doing that I just thought I place a question here to see if there is anybody with this experience and what you did to fix this problem.
Thank! great forum by the way.
Peter Lindström
Sweden2 December 2022 at 12:29 #41145Shelbysfoster
BRONZE MemberHello,
Since you didn’t post any basic cd player troubleshooting information,
there is little anyone can do to help other than suggest you do
standard cd player troubleshooting. Mynordstrom2 December 2022 at 14:41 #41146Dillen
ModeratorReplace capacitors on the decoder/audio PCB.
19 December 2022 at 00:25 #41147PeterL
BRONZE MemberHi.
Thanks for the input. I changed all capacitors and now it is working just fine.
Peter
