Home › Forums › Product Discussion & Questions › BeoLit › Can’t add Beolit 12 to the B&O App – crashes
- This topic has 5 replies, 3 voices, and was last updated 2 years, 2 months ago by
Djmp.
29 January 2024 at 06:59 #52480
Djmp
BRONZE MemberHi – I’m trying to add a Beolit 12 in the B&O app. The app detects the Beolit 12 and shows it “Nearby” but crashes when I select “Next”. Same behavior on iOS and Android. Anyone able to add a Beolit 12?
s/w version is Date 2012-03-26 /Version 1.02.12 and I did try a software update.
29 January 2024 at 14:27 #52481 Capt’nGerard, formerly known as Gaea
GOLD MemberSame here with a Beoplay A8, aperently known bug but not very high on their priority list.
It is best to complain to the helpdesk too.
29 January 2024 at 15:18 #52482 MillemisBRONZE MemberYou probably won’t succeed unless you connect the device via ethernet cable to your homenetwork.
Usually updating the software (of the Beolit 12/Beoplay A8) solves this problem…..once you have gained access to it.
29 January 2024 at 16:15 #52483Djmp
BRONZE MemberI opened a support ticket. Same problem if the is connected via Ethernet.
29 January 2024 at 22:06 #52484 Capt’nGerard, formerly known as Gaea
GOLD MemberMy A8 Is on latest software and was on ethernet too.
Support told me it’s a known bug, and I had to wait until it is solved
30 January 2024 at 15:12 #52485Djmp
BRONZE MemberJust got the same answer: “Our development team is already aware of this issue and they are working on a fix.”
