Home › Forums › Product Discussion & Questions › BeoVision › BV9 on the way upstairs
- This topic has 11 replies, 6 voices, and was last updated 2 years, 1 month ago by
YannChris.
2 March 2024 at 03:57 #53176
Ipe
BRONZE MemberHi,
I’m planing to “lift” BV9 upstairs. Corridor is too narrow and stairs…….hmmm. Does anyone have experience or has someone put that TV to smaller more lighter pieces? One can of course hire a crane:)
3 March 2024 at 18:16 #53177Valve1
GOLD MemberI have no idea what can be taken off. You would obviously need help but if your not comfortable trying this get a pair of house moving guys who are used to moving stuff in tight spaces.
It is worth keeping !
3 March 2024 at 18:20 #53178 YannChrisGOLD MemberHi,
Unfortunately, BV9 is a 110 kg monolith and I would not take the risk to dismantle it.
The best is to hire movers, you’ll take advantage of their tricks… and strength 🙂
Good luck,
Yann.
3 March 2024 at 18:21 #53179 YannChrisGOLD MemberValve, you were faster than me 🙂
3 March 2024 at 19:04 #53180Beoaddict
BRONZE MemberThe Beovision 9 is in fact extremely easy to disassemble, by far the easiest of all B&O TVs. The heaviest part ist the plasma panel, which ist attached with a few screws and connected to the Beosystem 3 only with a DVI connector and the mains cable. It took me around an hour to disassemble, transport and reassemble the unit within my house. The panel can be carried by one strong person or two guys of average build, as can the housing with speakers and Beosystem 3. I strongly recommend going this route.
3 March 2024 at 19:06 #53181Beoaddict
BRONZE MemberThe disassembly process is (briefly) covered in the service manual, which can be found on Beoworld or via google document search.
3 March 2024 at 21:04 #53182 MillemisBRONZE MemberMy only memory from such a job years ago was….back pain ?
4 March 2024 at 22:03 #53183Evan
GOLD MemberThe Beovision 9 is in fact extremely easy to disassemble, by far the easiest of all B&O TVs. The heaviest part ist the plasma panel, which ist attached with a few screws and connected to the Beosystem 3 only with a DVI connector and the mains cable. It took me around an hour to disassemble, transport and reassemble the unit within my house. The panel can be carried by one strong person or two guys of average build, as can the housing with speakers and Beosystem 3. I strongly recommend going this route.
Wow – did not expect this as a practical option. Why aren’t more people talking about this? If I had known this, I would have been shopping a BV9 vs what I could move up the stairs at my old flat!
6 March 2024 at 08:22 #53184Ipe
BRONZE MemberHi, been planing to move bv9 upstairs next weekend. Checked it (TV) a bit from here and there. Should not be a bad thing to do at all. Lets see how it goes:)
6 March 2024 at 08:29 #53185Ipe
BRONZE MemberHi, TV 124kg + two strong guys would be at least 300kgs. I really question durability of my old house stairs:) They also make 90 degree curve and are relatively steep……..
9 March 2024 at 10:01 #53187 YannChrisGOLD MemberHi,
As gold member, you have access to the service manuals at the end of this page:
https://www.beoworld.org/manuals_view.asp?pid=738
Regards,
Yann.
9 March 2024 at 17:03 #53186Ipe
BRONZE MemberFrom where did you begin to unscrew? From back or front? I did not find that kind of service manual with exploded view. Just ask because I don’t want to do extra work or any mistakes:)
