Home Forums General Discussion & Questions General Discussion & Questions BV11 on BV10 Stand–how to wire?
Viewing 8 posts - 1 through 8 (of 8 total)
  • #57538
    Gene Ku
    Looking for help with using a floor stand for a BV10 with my BV11 but the clips don’t match.
    How do I wire these together? (I’m not sure I numbered them correctly according to standard convention, but BV11 #1 goes to which BV10 #, BV11 #2 goes to which BV10 #, which BV10 # is ground, et cetera?)
    Thanks!
    Gene
    Screenshot_20240720-180213_GalleryScreenshot_20240720-180416_Gallery
    #57547
    Guy
    Normally I’d refer you to the service manuals (avail to Silver & Gold members), but here are screenshots from the relevant sections.  I am not convinced that it is straightforward but if you can get it to work please come back and let us know how!
    BV11:
    BV11
    BV10:
    BV10
    Madskp
    GOLD Member
    Normally I’d refer you to the service manuals (avail to Silver & Gold members), but here are screenshots from the relevant sections. I am not convinced that it is straightforward but if you can get it to work please come back and let us know how! BV11: BV11 BV10: BV10
    I would no be to sure that these stands are compatible. 12V on one vs 14V on the other. Two wires with twoway communication on one vs 3 wires with one way communication on the other.
    You have to be very sure what you do if you try to combine these
    #57550
    Gene Ku
    Thank you!
    I know to be careful which is why I asked!
    Is the numbering in the schematic the same as my numbering? I know there must be a convention, but I don’t know it.
    Out of curiosity, is the Avant wired the same as a BV11?
    Thanks again!
    #57551
    Guy
    I don’t know, but from inspection you can probably work out ground, and maybe find the 12V (or 14V) using a multimeter and then have an educated guess for the remainder!
    Looks the same in the service manual – this calls the connector a ‘MicroFit 4-pin’, if that’s any help.
    Gene Ku
    Thank you!
    I think this is exactly what I needed:
    https://iisb-foxbms.iisb.fraunhofer.de/foxbms/docs/latest/hardware/connectors.html
    Screenshot_20240802-185404_Samsung Internet
    #58025
    beouser19
    Member
    Bv10 stand are NOT electrical compatible with bv11 stand
    bv10 have turn left 5v and turn right 5v
    bv11 use CAN bus serial data
    #58091
    Gene Ku
    Thank you, Beouser 19!
    That is a big difference. I haven’t tried anything yet and looks like I shouldn’t.
    Is the stand from an Avant NG compatible with either BV10 or BV11?
