Home › Forums › Product Discussion & Questions › BeoVision › BV 9 and projector
- This topic has 2 replies, 2 voices, and was last updated 3 years, 1 month ago by
Ipe.
11 March 2023 at 04:23 #44518
Ipe
BRONZE MemberHi!
I have a problem with loudspeakers connected to BV 9.
If use with projector only loudspeakers on tv and subwoofer work.
Immediately when format in beo4 is pushed twice and picture shifts to projector
front speakers (beolab 8000) will cut off.
Any suggestions?
12 March 2023 at 11:05 #44519beoandy
BRONZE Memberhi! you must also configure the speakers in cinema mode. (roll, distance, volume, etc.) so switch to cinema mode (format 0) and go to the bv9 (bs3) menu on the cinema screen.
beoandy
12 March 2023 at 15:09 #44520Ipe
BRONZE MemberThanks, of course 🙂
Works fine now.
Ipe
