Home Forums Product Discussion & Questions BeoVision BV 10-40 problem no picture!
Viewing 8 posts - 1 through 8 (of 8 total)
  • #71632
    stotty1111
    GOLD Member
    Hi all
    Got a problem with my 10-40, yesterday, torrential rain here for a short period, Iuse a satelite dish, and I think the rain on the dish affected the detector etc.
    Signal returned everything as normal.
    This morning switched the set on, just a screen with lots of horizontal interference(?)  and diagonal lines.
    It would not respond to changes by the remote.
    I have looked at the engineering menu, the monitor info shows build as 127 but it is in red,
    Other info, mechanical type BV10-40 model 9570
    What should I be looking for/at, suggestions please
    More info will be supplied if needed!
    Tony
    #71650
    stotty1111
    GOLD Member
    Just had a couple of minutes to try the functionality with the connected PC, that works, so, i think it points to the tv section!
    Back at it tonight or tomorrow, its a bit time dependant!
    #71686
    stotty1111
    GOLD Member
    A little more info:-
    MONITOR INFORMATION
    Type No    9570
    Item No    1847431
    Serial No   22073022
    Option setting    1
    Build         127(shown in RED)
    PRODUCT TYPE
    Mechanical Type   BV 10-40
    Hardware Type    C22
    LCD Panel Type   LTA400HG01
    The set is fitted with a digital satellite card and a terrestrial card,  tuned to UK Freesat and French TNT respectively
    #71690
    Guy
    The Build type in RED is strange.  I searched using AI and it came up with:
    The red text for the “Build Type” in your BeoVision 10’s service menu indicates that the television is currently running on engineering, prototype, or non-standard service software, rather than the official consumer release.
    This status is an internal flag used by Bang & Olufsen technicians during development, testing, or specific repairs. It is not typically seen on a standard retail unit with regular software updates.
    On the Monitor page is there anything listed against the DVB-T/C field?
    Or is there a DVB service menu page with DVB CONNECTED shown as YES/NO?
    I would double check your satellite connections at DISH and TV end – can you check it with another TV?
    If all else fails I would be tempted to note all your settings (if you can view them) and then try a Factory Reset.
    • This reply was modified 3 months, 1 week ago by Guy.
    stotty1111
    GOLD Member
    Ok, thanks for that!
    No DVB-T/C listed in monitor info or anywhere else.
    and in the DVB Service Menu    DVB connected    yes
    the Monitor menu5 after those quoted earlier
    PW  328
    FEP
    FEP Bootloader
    FA Module
    STD Module
    System Module
    BTB Mdule
    DSM FEP
    DSM DSP
    DVB HD
    T CON
    I also contacted BnO Tech Support, they have given me a Historic BnO repairer but they are 350miles away near Rouen – last resort I think to visit, I will mail them tomorrow to ask if they have any suggestions / solutions to try.
    Meanwhile I will try to locate my list of engineering settings prepared earlier in the year to compare with now  –  it would also give me the working Build number.
    • This reply was modified 3 months, 1 week ago by stotty1111.
    #71740
    stotty1111
    GOLD Member
    Et voila!!!😃
    Switched on this morning, still the same situation, looked at the BnO menu page, went to
    options, tv setup, ticked both boxes then clicked on DVB and the world opened up.
    Could choose language country satellite etc.
    And after the next click everything started to reload, after reload had finished rebooted tv and french tv was available and with the sideways arrow to the right freesat came up   —   BRILLIANT, —- I am now a happy bunny!!
    I now just need to recreate my personal channel list, a bit of a ballacher, takes a couple of hours, but hey what’s that over paymens to a distant repairer!!!
    Monitor info still showing Build 127 in red, I think I can live with that though!😉
    Tony a la Finistere
    #71744
    Guy
    Great news – have a good weekend!
    stotty1111
    GOLD Member
    Have now finished setting up the tv, just checked the Monitor Info area and the Build 127 is now back to black — maybe it’s a no programs loaded thing?
