Home › Forums › Product Discussion & Questions › BeoSound › BS9000 Mk3 (Type 2571) – New laser fitted, TM71 passes, TM73 fails, intermittent
- This topic has 0 replies, 1 voice, and was last updated 10 minutes ago by
Jeroen Medema.
20 October 2026 at 23:14 #126028
Jeroen Medema
BRONZE Member<style>
a {
text-decoration: none;
color: #464feb;
tr th, tr td {
border: 1px solid #e6e6e6;
tr th {
background-color: #f5f5f5;
</style>Hi all,
I’m looking for advice on a BeoSound 9000 Mk3 (Type 2571) with an intermittent CD problem.
<h3>Background</h3>
The original optical pickup was replaced with a new unit from Quickcycle. The replacement part number was verified against the original before installation.Unfortunately, the symptoms remained largely unchanged after the replacement.
<h3>Symptoms</h3>- Sometimes CDs start immediately.
- Sometimes the player ends up in PAUSE.
- Sometimes repeated retries eventually succeed.
- Once playback has started, track skipping often works normally.
- Occasionally the system can switch between multiple CDs without issue.
- At other times several CDs fail one after another.
- On at least one occasion the player was playing normally and then stopped abruptly.
- During some failed attempts the disc appears to accelerate to an unusually high speed.
<h3>Service mode results</h3>
TM71- Passed successfully (TM OK).
TM73
- Fails on all CD positions.
- Disc spins up rapidly, then reports an error.
- Position 1 reports error 7.
- Positions 2-6 report error 3.
TM63
- Starts the turntable motor.
- Disc appears to rotate at a very high speed.
TM67
- Behaves the same as normal playback.
- Usually ends in failure.
<h3>TM27 error log</h3>
After clearing the log and running only TM67 until failure:- Multiple CD error 3 entries (radial error).
- Multiple CD error 7 entries (subcode error).
- Two APS error 15 entries.
Notably:
- No CD error 2 (focus error).
- No new CD error 4 (turntable motor error).
<h3>Questions</h3>
Given these test results:- Would you suspect the new pickup, the pickup ribbon cable/connection, PCB41 (servo board), or something else?
- Is a failing TM73 after pickup replacement pointing towards a known issue?
- Has anyone seen a BS9000 that can sometimes play perfectly and then suddenly stop, while producing mainly CD error 3 and 7?
Any suggestions would be greatly appreciated.
Thanks, Jeroen
