Home › Forums › Product Discussion & Questions › BeoMaster › bought a Beomaster 4500 with COde error
- This topic has 1 reply, 2 voices, and was last updated 4 hours, 52 minutes ago by
25 September 2025 at 18:16 #69897BRONZE Member
I bought a “broken” Beomaster 4500 cheap. After plugging the BM4500 to the mains, it displayed the COde error.
After the “1 2 7 1 trick” the BM4500 seems to work normal.Will a new battery solve this problem completely?
What are the experiences? Please advice
This topic was modified 21 hours, 8 minutes ago by
26 September 2025 at 10:35 #69904ModeratorI’ve only carried out the procedure on a couple of BC9500s, but no-one else has replied.
For me, a new battery solved the problem – I think I had to carry out the COdE procedure again after battery replacement, but there have been no further problems since with either system.
In my experience, if you keep the system connected to mains power the problem may not re-occur – my mother-in-law’s system failed early because she switched it off at the wall every night. However, if the battery is flat then it may be close to leaking, hence worth replacing.
I’m currently debating changing the battery in a BS3000 that I have taken apart for door/CD belt changes – will probably do so to give it a longer lifespan.
