Home › Forums › Product Discussion & Questions › BeoMaster › BM3500 connected to Beolink Converter & MCL2A?
- This topic has 5 replies, 2 voices, and was last updated 3 years, 10 months ago by
pepps.
10 May 2022 at 01:47 #34733
GuyModeratorI am not sure of your membership status but Gold and Silver Members are able to view the manuals. The Master Control Link handbook (listed first in this link as ‘Handbook’)) has sample setups similar to your proposals: https://beoworld.org/manuals_view.asp?pid=973
10 May 2022 at 11:41 #34729 peppsModeratorHello Beoworld,
I’d like to know if it’s possible to connect both a Beolink Converter (type 1161166) and a MCL2A to my Beomaster 3500?
Currently I have the BM linked to my BV7-40 by the Beolink Converter (audio aux link to masterlink).
I would like to connect an X-tra Speakers kit to the same Beomaster to run a music connection to my office.Can anyone see any problems with this?
Julian
Favourite Product: Beosystem 6500
10 May 2022 at 12:20 #34730 GuyModeratorYes an MCL2A would work fine; it connects to the BM3500’s speaker 2 sockets.
However, the MCL2A system has fixed volume (i.e same volume when listening in both main room and office). For independent volume control, you may wish to consider extending the ML part of your system into the office, and add a Beolink Passive instead.
10 May 2022 at 13:28 #34731 peppsModeratorHello,
Thanks for your reply. That’s good to know I could run the two technologies together. On the whole it would just be me playing my records from the living room in my office during the day. Nobody else is at home during this time so independent volume control wouldn’t be an issue.
I’m curious though, if I activated the Beogram in the lounge from my office via MCL2A would that trigger the Beolink Converter to fire up my Beovision and consequently the speakers in my living room? That would be annoying and was the main reason for my concerns about having MCL2A and an Audio Auxilary Link system connected to the same Beomaster.
This sounds very sensible but I wouldn’t know where to start with the set-up: Audio Auxilary Link to Beolink Converter to Masterlink to Beovision – I would have to split the ML cable and branch off to the office – would that confuse everything even more???
The MCL2A option does seem simpler if my concerns above are unwarranted.Julian
10 May 2022 at 13:40 #34732 GuyModeratorI’m curious though, if I activated the Beogram in the lounge from my office via MCL2A would that trigger the Beolink Converter to fire up my Beovision and consequently the speakers in my living room?
No it wouldn’t. The BM3500 would start up but it would be muted. The TV and its connected speakers should stay off.
Yes you’d have to split the masterlink cable or use a ML junction box – I find that the ‘plug-in’ type is best to avoid cutting wires or cutting off plugs. In the office you’d then need a Passive with an ML-eye and of course some passive speakers. This system should work well.
I agree -if you are happy with the volume limitations. There is however a way to get ‘pseudo-independent’ volume control in an MCL2 link room: Instead of an MCL2A you could add an MCL2AV, but this has Powerlink Outputs so you’d also need a Passive or MCL2P amplifier in order to get volume levels that can be different to the main room. If you do want independent volume then an ML extension is a better solution.
10 May 2022 at 14:07 #34734 peppsModeratorI am not sure of your membership status…
I have the full Tony Hadley 🙂
I’ll check for those examples of set-ups.Thank you sir!
