Home › Forums › Product Discussion & Questions › BeoMaster › BM3500 / BM4500 similarity
- This topic has 6 replies, 4 voices, and was last updated 3 years, 6 months ago by
Llurkio.
11 September 2022 at 09:11 #38998
Llurkio
BRONZE MemberHi everyone, A quick question followed by the reason.
Is the only difference between a BM3500 and a BM4500 cosmetic ?
I aquired a cheap BM4500 a few months ago, it had a fault with the FM/MW tuning board and another problem I’m struggling to trace, but it in beautiful condition, then I had the option of buying a BM3500 for next to nothing – in very poor condition, the glass control panel is missing (presumably broken) but everything appears to work perfectly, my plan is to transfer the ‘guts’ of the BM3500 into the BM4500 case. I would have to use the glass control panel of the BM4500, but they look identical – thoughts anyone, especially about the EPROM – what if “CODE” comes up, is this then an automatic scrapper ?
(And before anyone says just put the lid and control panel on the BM3500 – it doesn’t have the nice white sides of the BM4500).
Tim
11 September 2022 at 22:10 #38999Dillen
ModeratorBeomaster 3500 has no timer functions and it doesn’t support two-way remote control.
12 September 2022 at 20:29 #39000Llurkio
BRONZE MemberI suppose the obvious question then is, will the BM3500 work using the BM4500 glass control panel – despite the loss of the timer functiom ?
Tim
12 September 2022 at 23:16 #39001Glitch
BRONZE MemberYou might be able to figure out some compatibility information by looking at the part numbers listed in the service manuals. I haven’t done this for the Beomasters that you have listed, but have done it for some other ones.
Glitch
13 September 2022 at 23:13 #39002Llurkio
BRONZE MemberThe control PCBs were found to be identical (the 3500 even had a timer pin – complete with griplet – I think that’s what they’re called), I put the 4500 glass control panel on and every thing appeared to work, I can mange without the timer – I’d never use it anyway.
I gave the 3500 a really good clean inside (it needed it) along with the 4500 nice shiny lid and I may colour the sides white (somehow).
So I have a good working 3500 dressed as a 4500 !
There will an advert soon, a non-working, not complete BM4500 for sale – no glass panel, with a 3500 ‘lid’, with a couple of faults – it may be useful to someone.
15 September 2022 at 18:39 #39003 StoobieGOLD MemberLlurkio,
One way to “colour” the unit would be to use white fablon (sticky back plastic). If you make sure the surface you apply it to is clean and no dust etc it will go on smoothly. I would make a template, cut the fablon slightly bigger and then you can carefully trim with a sharp craft knife. Added bonus is it is reversible.
I did this to change a black LX6000 TV to white and it looked awesome. I have also used a mirror finish fablon on the side of my Beocom 6000 pyramid base and on my Lintronic box. They look good too.
Stoobie
15 September 2022 at 22:07 #39004Llurkio
BRONZE MemberGreat minds think alike Stoobie, the sticky back plastic is already on order !
(I like the mirror finish idea, that could look good too ).
Tim
