Home › Forums › Product Discussion & Questions › BeoLink › Beolink ML/NL version number? 1.4, 1.3
- This topic has 10 replies, 6 voices, and was last updated 20 hours, 8 minutes ago by  kallasr. kallasr.
3 January 2023 at 07:47 #42054XavierItzmann BRONZE MemberSo, I need one of these as I was away during the transition years and all my old equipment is MasterLink and B&O no longer sells this critical component. Is it true that these are no longer consumer updatable? What’s a man to do then? If I buy one, is there a minimum version I should get? Are there substantial performance differences? I found an old post here in the forum that cited the final version number but then I lost it. Thanks in advance. 3 January 2023 at 12:02 #42055Hi Xavier, Both my BLCs are “1.4.3.19864, December 11, 2015” and they work fine. Hope this helps. Regards, Johan Location: Netherlands My B&O Icons: 3 January 2023 at 16:18 #42056XavierItzmann BRONZE MemberThank you Johan. I’ll be asking any sellers about the software version installed on their BeoLink Converter NL/ML, and will only buy if it is 1.4.3.19864 or higher. 3 January 2023 at 21:30 #42057Hello Xavier, Johan has mentioned what is to my knowledge the final sw version. Last year, I had to order a repair of one of my BLC ´ s and they needed to exchange the electronics completely. So, more or less a new unit, and it says sw is on 1.4.3.19864. You should be careful indeed, and buy only a BLC with the latest sw version. If it is on a lower level sw version, it may be so because of faulty electronics. The sw versions of the BLC are, from latest to older: 1.4.3.19864 – Final version 1.4.3.19816 1.4.2.19611 1.4.1.19522 Those are the ones I know about. Kind regards, Rolf Location: Germany Favourite Product: BeoSystem 4500 My B&O Icons: 4 January 2023 at 16:43 #42058XavierItzmann BRONZE MemberAhh, yes, Rolf, thanks for your detailed advice. The current range of Connected products is set by default on software “auto-update”, so when devices currently updated by B&O cease to be upgraded, most will be left on the final version. Which prompts me to ask… at the time the BLCs were current, did “auto-update” exist? Because then you’d be doubly right to question the full functionality of items being sold with less than the final version! (unless the devices were stored in a drawer, one might think). 4 January 2023 at 16:49 #42059XavierItzmann BRONZE MemberThanks, MM! Since these BLC’s had recommended auto-update, most good ones should be on 1.4.3.19864! Now I just have to get one. 6 January 2023 at 10:39 #42061Go and grab one and enjoy your ML products working together with NL products! Kind regards, Rolf Location: Germany Favourite Product: BeoSystem 4500 My B&O Icons: 19 May 2025 at 09:03 #65698Ce Lee BRONZE Member4 June 2025 at 21:27 #66196A dealer will be able to upgrade your product. Updating online is no longer available. Kind regards, Rolf Location: Germany Favourite Product: BeoSystem 4500 My B&O Icons: 30 October 2025 at 11:22 #70781 kallasrFOUNDER Member kallasrFOUNDER MemberBefore installing my newly acquired BLC I wanted to install the latest software (it runs on version 1.4.0.18322). Just learnt it is not available for download anymore.
 It is a shame, it does not update anymore by itself.
 Since I do have the software itself, I’d just need the Service Tool MK2+ to install it.Any chance this can be provided by someone on this Forum? Thanks in advance.
 RalfLocation: NRW, Germany Favourite Product: Beo 4 Signature: BV 11-46, BV7-40, BS 4, BS9000, BL11, BL9, BL7-2, BL3, BL4000, BL6000, BL8000, BG4500d, Beoport. My B&O Icons:
